Tools needed to fix anything on a 50cc honda scooter.
A list of tools needed to fix anything on a 50cc Honda scooter
socket set 17mm 14mm 12mm 10mm 8mm and a spark plug socket.
10mm wrench is a must have.
compression tester (14mm)
#2 Phillips screwdriver
#1 flat screwdriver for adjusting jets
Strap wrench for holding clutch bell
Spark plug gap gauge
Flywheel puller tool
Tusk tool (crank install tool)
Torque wrench
Tire spoons
Small Tire Changer
Metric Allen Wrenches
Needle nose pliers
Tire Pressure Gauge
Cordless Impact Wrench (For disassembly ONLY)
Bearing separator
39mm socket for clutch nut
45mm socket for handle bars and forks
Universal pulley holders
Snap ring pliers
Hose cutter
DVM
Wire strippers
Wire crimpers
Battery charger
Air compressor and tire gauge
Thread chasers
Cleaning brushes and wire for carb cleaning.
7mm for removing restrictor and grease plates
Bearing puller for transmission case bearings and wheel bearings
Sharpie markers for marking the Variator
Gram scale for measuring roller weights.
Digital calipers for measuring belt thickness
Syringe for transmission oil
4mm wrench.... cause eliteguy50 said I need one :wink:
Spring Pullers
Digital Camera
soldering iron
Heat gun
Jumper leads
20 ton press for pressing gears
Magnetic parts bowl
Kneeling pad or knee pads (you older guys know what I'm talking about) :wink:
Wash tank big enough to put the whole engine in for cleaning.
Glass bead cabinet for serious cleaning.
crankcase pressure and vacuum tester
magnetic grabber
3 prong grabber/puller tool
Steering wheel puller tool, to separate the case halves
Bench Vise
Bench Grinder
Welder
Torch O/A
Dremel tool/ bits for porting
Brake hone
Re: Ultimate Tool Box for a Honda scooter.
...philipps...
Oh yes a #2 phillips screwdriver for sure.
added to the list
What else?
since you're making the "ultimate tool box"....strap wrench ?
Post by eliteguy50 »
Flathead depending on your carb adjustments.
GAP GUAGE
...tire spoons...air guage
flywheel puller tool
Tusk tool
torque wrench
motormike wrote:...tire spoons...air guage
Tire spoons? :confused:
Oh tire spoons
I learned something today.
I have this tool for changing tires.
ragtop89
Post by ragtop89 »
Metric Allen Wrenches, needle nose pliers, tire patch kit.
83' Aero NH80
86' Yamaha Riva 125Z
motormike wrote:GAP GUAGE
GUAGE???????? Try GAUGE. :smile:
...that dam* swimmingfree...
how about an air guage :smile:
deuce217
Post by deuce217 »
Makita impact with 1/4'' and 3/8'' adapters to fit your sockets. THIS SAVES TONS OF TIME!
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
