Page 1 of 4
Tools needed to fix anything on a 50cc honda scooter.
Posted: Wed Apr 11, 2012 12:06 am
by Trafficjamz
A list of tools needed to fix anything on a 50cc Honda scooter
socket set 17mm 14mm 12mm 10mm 8mm and a spark plug socket.
10mm wrench is a must have.
compression tester (14mm)
#2 Phillips screwdriver
#1 flat screwdriver for adjusting jets
Strap wrench for holding clutch bell
Spark plug gap gauge
Flywheel puller tool
Tusk tool (crank install tool)
Torque wrench
Tire spoons
Small Tire Changer
Metric Allen Wrenches
Needle nose pliers
Tire Pressure Gauge
Cordless Impact Wrench (For disassembly ONLY)
Bearing separator
39mm socket for clutch nut
45mm socket for handle bars and forks
Universal pulley holders
Snap ring pliers
Hose cutter
DVM
Wire strippers
Wire crimpers
Battery charger
Air compressor and tire gauge
Thread chasers
Cleaning brushes and wire for carb cleaning.
7mm for removing restrictor and grease plates
Bearing puller for transmission case bearings and wheel bearings
Sharpie markers for marking the Variator
Gram scale for measuring roller weights.
Digital calipers for measuring belt thickness
Syringe for transmission oil
4mm wrench.... cause eliteguy50 said I need one :wink:
Spring Pullers
Digital Camera
soldering iron
Heat gun
Jumper leads
20 ton press for pressing gears
Magnetic parts bowl
Kneeling pad or knee pads (you older guys know what I'm talking about) :wink:
Wash tank big enough to put the whole engine in for cleaning.
Glass bead cabinet for serious cleaning.
crankcase pressure and vacuum tester
magnetic grabber
3 prong grabber/puller tool
Steering wheel puller tool, to separate the case halves
Bench Vise
Bench Grinder
Welder
Torch O/A
Dremel tool/ bits for porting
Brake hone
Re: Ultimate Tool Box for a Honda scooter.
Posted: Wed Apr 11, 2012 12:18 am
...philipps...
Posted: Wed Apr 11, 2012 12:22 am
by Trafficjamz
Oh yes a #2 phillips screwdriver for sure.
added to the list
What else?
Posted: Wed Apr 11, 2012 12:29 am
since you're making the "ultimate tool box"....strap wrench ?
by eliteguy50
Flathead depending on your carb adjustments.
Posted: Wed Apr 11, 2012 12:31 am
GAP GUAGE
Posted: Wed Apr 11, 2012 12:32 am
...tire spoons...air guage
Posted: Wed Apr 11, 2012 12:35 am
by Trafficjamz
flywheel puller tool
Tusk tool
torque wrench
Posted: Wed Apr 11, 2012 12:36 am
by Trafficjamz
motormike wrote:...tire spoons...air guage
Tire spoons? :confused:
Posted: Wed Apr 11, 2012 12:39 am
by Trafficjamz
Oh tire spoons
I learned something today.
I have this tool for changing tires.
Posted: Wed Apr 11, 2012 12:49 am
by ragtop89
Metric Allen Wrenches, needle nose pliers, tire patch kit.
Posted: Wed Apr 11, 2012 1:11 am
motormike wrote:GAP GUAGE
GUAGE???????? Try GAUGE. :smile:
Posted: Wed Apr 11, 2012 1:16 am
...that dam* swimmingfree...
Posted: Wed Apr 11, 2012 1:18 am
by Trafficjamz
how about an air guage :smile:
Posted: Wed Apr 11, 2012 1:22 am
by deuce217
Makita impact with 1/4'' and 3/8'' adapters to fit your sockets. THIS SAVES TONS OF TIME!
