oko type carb is flowing gas out
Posted: Wed Apr 11, 2012 7:08 pm
by iceman77
I have a brand new oko type carb and when i hooked it up gas wont stop running out of the overflow hole. any help would be awesome.
TJ
Re: oko type carb is flowing gas out
Posted: Wed Apr 11, 2012 7:47 pm
by Mystic
check the float and float valve
Posted: Wed Apr 11, 2012 9:18 pm
by iceman77
i've checked the float level and adjusted it but it hasn't helped.
TJ
Posted: Wed Apr 11, 2012 10:08 pm
by fatcharlie
I'm not familiar with the OKO specifically, but if its coming out of the overflow with the carburetor vertical, then for some reason, your float needle isn't seated all the way.
Pull the carb off and remove the float bowl, hook up a line with fluid in it while holding the float at the "full level"... you'll see fuel coming out from somewhere...
My bet would be on either:
A: an improperly assembled float assembly.
B: a damaged or dirty seat or needle
C: an improperly adjusted float level.
Posted: Wed Apr 11, 2012 11:31 pm
by Trafficjamz
This carb worked just fine when I used it less than a week ago.
Could shipping it have messed something up.
Can a bad petcock and a full gas tank put too much pressure on the float needle, and make a good carb bad?
Posted: Thu Apr 12, 2012 12:18 am
Trafficjamz wrote:This carb worked just fine when I used it less than a week ago.
Yes, to all of that.
Posted: Thu Apr 12, 2012 1:54 am
by bakaracer
no to the last question. fuel pumps can be used on these same carbs with no issues.
Posted: Thu Apr 12, 2012 1:56 am
by bakaracer
iceman77 wrote:I have a brand new oko type carb and when i hooked it up gas wont stop running out of the overflow hole. any help would be awesome.
TJ
how did you check to see where the float level is at? what did you do when you adjusted it?
Posted: Thu Apr 12, 2012 2:08 am
by Trafficjamz
bakaracer wrote:iceman77 wrote:I have a brand new oko type carb and when i hooked it up gas wont stop running out of the overflow hole. any help would be awesome.
TJ
I sent him a PM with this link earlier today.
http://www.allthingsmoto.com/forums/f-1 ... ary-13608/
Posted: Thu Apr 12, 2012 2:24 am
Here is my choice for checking float level. Quick, easy and accurate.
Posted: Thu Apr 12, 2012 2:32 am
by Trafficjamz
the gas is even pouring out the mouth of the carb past the filter.
this has got to be a float needle problem or the float itself is stuck
Posted: Thu Apr 12, 2012 7:40 am
by iceman77
Trafficjamz wrote:the gas is even pouring out the mouth of the carb past the filter.
this is true. i forgot to mention that it was coming out of the mouth also.
TJ
Posted: Thu Apr 12, 2012 5:58 pm
by kingkamehameha
Take your carb apart and cleat the float needle seat with a qtip and some tooth paste
