Does this seem low? The guage is one i rented from O'reilly and i DID use the small adapter that came with it, which would seem to lower the pressure reading due to adding volume to the cylinder.
I used the same tester with and without the adapter on a friends Rattler 110cc and the results without the adapter were 150 psi and without ~145.
My scoot thus far seems to top out at 64mph at about 9100 with the corsa bore and PG short pipe, 8.44 gears and breathing through an oko 24. Some of you guys are hitting 70, but i spose you have pipes that are geared more towards peak power.
