drive belt - 87 spree
Posted: Tue May 09, 2006 12:51 am
by mlangdon521@hotmail.com
how tight should the drive belt be on the 87 spree? also, is there a tensioner or some way to tighten a lose belt?
Posted: Tue May 09, 2006 7:05 am
by darat
wait y is ur name like 5k words long its a nick name not a email address
Posted: Tue May 09, 2006 7:44 am
by tonrogs
It will tension itself. That back pulley should pull it tight. The back pulley has a spring that pushes the two pulley halves together and forces the pulley outward, this is what auto-tensions your belt. If your belt is loose, then you most likely need a new belt. Double check that your rear pulley is operating properly though too.
Posted: Tue May 09, 2006 8:32 am
by MySpree
i have extra belsts
Posted: Tue May 09, 2006 9:10 am
by mopedman
you probly need a new belt, i have one
