Speedometer/Odometer not working now...
Posted: Mon Apr 16, 2012 4:08 pm
by Old Dad
Just changed the tires on my 86 elite 150 and the speedometer and odometer are now not working. This is very odd. The gear turns and the cable is properly connected. I've changed the brakes a couple of times before, so I've removed the tire several times and put it back on without any problems. Any ideas?
Re: Speedometer/Odometer not working now...
Posted: Fri Apr 20, 2012 7:35 pm
by Dio89Elite
The cable is properly connected... where? Did you check both ends? It may have come loose at the gauge end or double check that you re-installed it properly at the wheel end.
Posted: Sat Apr 21, 2012 3:27 pm
by Old Dad
I figured it out. I took the cable off again, pulled on one end slightly, and the whole thing came out of the conduit. So, its gonna be a new cable for me.
