is the polini kit ok to stroke?
- scottinscotty
can you stroke a polini kit? and what would be the benefit?
72cc polini contesa kit
oko variator with 8.5 gram malossi weights
21mm Black Oko Carb & Ct Manifold
8.44 gear
malossi MHR exhaust
Dio zx trans conversion
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
8.44 gear
malossi MHR exhaust
1000 center spring
1500 grabbers
sef ramp plate
B9hs plug
GPS 60mph
- kingkamehameha
Re: is the polini kit ok to stroke?
You can ministroke it but the stock crank is more reliable
- KingJeff801
nice avatar ....whos the lady?
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
if you can get the port timing recorrected then you can make more power. if you dont know what to do then I would suggest you not go that route. your best bet is to get a corsa. the contessa is a street port kit which basicly is a little better port timing than stock just bigger piston for more torque. the corsa is the race kit so more power and rpm.scottinscotty wrote:can you stroke a polini kit? and what would be the benefit?
get a stock stroke crank are much reliable than mini stroker crank!
