Page 1 of 2
Fuel Flow Problem (in carb)
Posted: Tue May 09, 2006 5:04 pm
by Farfignugin
The Problem: Fuel flows at idle; no vacume at high rev; petcock, filter, strainer, vacume line all fine.
Possible causes: something wrong with float? (if so what?)
Btw, this is an update to the "Interesting problem with trottle" topic.
Any help again would be much appreciated.
Thanks in advance.
Posted: Tue May 09, 2006 9:57 pm
by Farfignugin
Update: float is fine, along w/ reed valves, what could be wrong????
Posted: Wed May 10, 2006 12:19 am
by hondaman
Possible small obstruction in gas line? Try putting a new line on.
Posted: Wed May 10, 2006 7:20 am
by Farfignugin
gas flow is fine, but when I checked the vacuume when the scooter is running, its ok at idle, but when I throttle up there is no vacuume. What could cause this?
Posted: Wed May 10, 2006 7:27 am
by stankyoleman
maybe a vacuum leak somwhere in the carb.... maybe when you're throttling up, the vacuum becomes greater, draws more gas and the leak gets worse and voila no vacuum. check to see and make sure that you have a rubber gasket attatched to the upper part of carb on the seam that seals off both halves.
Posted: Wed May 10, 2006 8:19 am
by mopedman
yea that would explan it
Posted: Wed May 10, 2006 9:13 am
by Farfignugin
yes there is a gasket
Posted: Wed May 10, 2006 9:46 am
by mopedman
this is a tuff problem....hmmmm.... i dk
Posted: Wed May 10, 2006 11:52 am
by Farfignugin
i don't know either, the only thing i do know is what is wrong, not why, or how to fix it.
Posted: Wed May 10, 2006 12:57 pm
by hondaman
Are you sure your vaccuum line does not have a small hole or split in it?
Posted: Wed May 10, 2006 2:03 pm
by mopedman
yea cuz that would realy explane it
Posted: Wed May 10, 2006 3:23 pm
by Farfignugin
yes, tested with a vaccume pump and it held vaccume.
Posted: Wed May 10, 2006 4:28 pm
by Farfignugin
Update: replaced all lines (fuel, oil, vaccume); Problem remains, not something to do with vaccume, but rather the float (might be sticking) cause fuel flows fine with vaccume, but doesnt flow when running.
Anyone know a reliable online place to buy a carb rebuild kit?
Posted: Wed May 10, 2006 5:18 pm
by noiseguy
If the gaskets are fine, how's compression?
Also wondering if your petcock is getting old and sticky, so that it doesn't open on throttle. Vacuum should dip, but not disappear, on throttle.
Posted: Wed May 10, 2006 7:50 pm
by Farfignugin
compression is fine, maybe i should check the petcock...
