aero backfires
Posted: Wed May 10, 2006 9:28 pm
by MySpree
ok well i installed my bore kit on there with ALOT of problems. and i mean alot. bolt holes wouldnet match, finally i got them perfectly there anit it bolted on. well first the aero wouldent start then when it did start the engine ran for 10 seconds then backfired and died... why would it do that! need help!
Posted: Wed May 10, 2006 10:28 pm
by Farfignugin
isnt backfiring a sign of running a little lean??
Posted: Wed May 10, 2006 11:12 pm
by stankyoleman
yea it is
aero
Posted: Thu May 11, 2006 12:13 am
by the496rocket
Just a thought, if you got the same kit is me, it doesnt dound like it, but did you make sure the piston went in the right way? my kit had one side of the piston with ports, so it was important to install right, if not, I would say upjet, what size jet are you running now?
Posted: Thu May 11, 2006 7:48 am
by MySpree
well im running an 80 and i made the arrow go to t he exaust port...
Posted: Thu May 11, 2006 8:48 am
by darat
well i think that u need pro to comeover and show you a couple of tricks.
Posted: Fri May 12, 2006 12:14 pm
by mopedman
i think that i agree with matt
Posted: Sat May 13, 2006 10:36 am
by darat
lol
Posted: Sat May 13, 2006 10:37 am
by MySpree
i found the prob, runs good now.
Posted: Sat May 13, 2006 10:40 am
by darat
sure sure so do u think u can still beat me?
Posted: Sat May 13, 2006 10:50 am
by MySpree
uhh yea. i do. and it was the elite s carb has a oil inlet on the carb insted of on the intake. well i had it on the intake and left the oil one empty... so i jsut oil to the carb and closed the other oil intake.
