I just bought a top end rebuild kit for my 1985 spree. New cylinder, piston, rings, gaskets etc. The rings have no writing on them. I know that the darker thicker ring goes on top per the seller and the fact it will not fit in the bottom groove, and the smaller shiny ring goes in the bottom groove. But........the seller said they also have to be flipped right side up. I am not sure which way that is. They have no markings on them.
It appears to me that each ring has a flat side and a beveled or
tapered side. It is very hard to see, but that's what it looks like.
What I need to know is, does the bevel face up or down? How can I tell
which way the ring faces? Does the bevel face up on BOTH rings? Only
on the top Ring??? I am not sure.
Also, the base gasket provided in the kit appears that it is missing cut-outs where it contacts the base of the cylinder and the top of the crankcase. I think maybe the areas I am talking about are the intake ports??
Anyway, shouldn't these areas be cut out of the base gasket? I have attached a picture of a base gasket that has those areas cut out (you can see them at the 9 o'clock and 3 o'clock positions). Mine DOES NOT have the cut out areas. Will mine work? I would think so since it came with the kit. Does anyone have any experience with these Ebay kits?
Lastly, should I smooth the edges of the ports inside the cylinder,or is it necessary?
Any help would be appreciated.
Thanks, Jeff
Help with Spree Piston Ring Install
a1parrothead
- base gasket.JPG (12.86 KiB) Viewed 3394 times
Re: Help with Spree Piston Ring Install
http://hondaspree.net/wiki/index.php5?t ... eplacement
Here is a link to the Wikispreedia piston ring replacement guide.
Get familiar with Wikispreedis, it is valuable.
No worries though, always post when in doubt....
a1parrothead
Thanks. I read the whole write-up already and it does not answer my questions. In the write up it is not specific enough.
Jeff
Jeff
Sorry for wasting your time.
I can only answer this: the rings are installed with the bevel UP
a1parrothead
No waste of time! Thanks for the help. It was a great write-up, just not specific to this kit. I put the rings on bevel up, and will figure out the rest. Thanks again for the help!
Maybe I'm the one who should become familiar .........
