24mm oko stock pipe
24mm oko stock pipe
Where should i start?
I have a 48 pilot and a 125 main.
It only seems to want to run on choke and stalls when i give it over 1/2 throttle. :confused:
going to see what jets I have......
Re: 24mm oko stock pipe
hmmmm all mains a r too big or too small :sad:
time to order jets i guess.
bakaracer
Post by bakaracer »
Trafficjamz wrote:Where should i start?
so with the choke on you can ride the bike?
I tried 52 pilot and 130 man and it works pretty good.
I'll report temps tomorrow.
bakaracer
Post by bakaracer »
Trafficjamz wrote:I tried 52 pilot and 130 man and it works pretty good.
oh crap thats big for a stock pipe. check for a leak somewhere or that carb just runs lean.
S4Patrick
Post by S4Patrick »
I'm running an OKO 24mm carb with the following:
Power jet plugged with two ball bearings
Pilot: 50
Main: 120
Needle clip: middle groove (JJH needle)
UNI two-layer air filter
1-3/4 turns out on the air screw
Cold start is excellent, idles pretty darn good, and nice throttle response at any RPM.....
72cc Corsa bore with SEF Magic Replica pipe (resembles a PG long to some extent)
Hope this helps.... :thumbsup:
'92 Super Dio ZX - AF18 Corsa
CAPT
Post by CAPT »
Delete
