24mm oko stock pipe
Posted: Thu May 03, 2012 3:44 pm
by Trafficjamz
Where should i start?
I have a 48 pilot and a 125 main.
It only seems to want to run on choke and stalls when i give it over 1/2 throttle.
going to see what jets I have......
Re: 24mm oko stock pipe
Posted: Thu May 03, 2012 3:46 pm
by Trafficjamz
hmmmm all mains a r too big or too small
time to order jets i guess.
Posted: Thu May 03, 2012 9:57 pm
by bakaracer
Trafficjamz wrote:Where should i start?
so with the choke on you can ride the bike?
Posted: Thu May 03, 2012 11:54 pm
by Trafficjamz
I tried 52 pilot and 130 man and it works pretty good.
I'll report temps tomorrow.
Posted: Fri May 04, 2012 12:01 am
by bakaracer
Trafficjamz wrote:I tried 52 pilot and 130 man and it works pretty good.
oh crap thats big for a stock pipe. check for a leak somewhere or that carb just runs lean.
Posted: Fri May 04, 2012 8:48 am
by S4Patrick
I'm running an OKO 24mm carb with the following:
Power jet plugged with two ball bearings
Pilot: 50
Main: 120
Needle clip: middle groove (JJH needle)
UNI two-layer air filter
1-3/4 turns out on the air screw
Cold start is excellent, idles pretty darn good, and nice throttle response at any RPM.....
72cc Corsa bore with SEF Magic Replica pipe (resembles a PG long to some extent)
Hope this helps....
Posted: Sat May 05, 2012 5:38 pm
by CAPT
Delete
