Page 1 of 2
Motoworks exhaust?
Posted: Wed May 09, 2012 9:21 am
by Force4000
Picked up a parts Spree last night, has a Motoworks older looking exhaust pipe on it. Cant find anything on google except all of motoworks new pipes. Any help would be appreciated. Ill post pics and a sound clip asap.
Re: Motoworks exhaust?
Posted: Wed May 09, 2012 10:53 am
by Force4000
heres the sounds clip. Hard to see the pipe but it sounds good.
http://www.youtube.com/watch?v=HcdBzpSUq7Y
Posted: Wed May 09, 2012 11:14 am
by swimmingfree
you shood of done the vid out side we can see more...
Posted: Wed May 09, 2012 11:17 am
by Force4000
Yea it was really dark last night and my phone is crappy for good video. Ill take a picture after work and post it.
Posted: Wed May 09, 2012 11:47 am
by wiguy05
Someone actually rode that Spree like that? My god
Posted: Fri May 11, 2012 9:26 am
by Force4000
Finally got pics. Any know anything about these old pipes?
Posted: Fri May 11, 2012 10:48 am
There is a phone number, call them and ask.
Posted: Fri May 11, 2012 11:07 am
by Force4000
Tried that number is long gone. Out of service at this point. Looks like motoworks also moved from Milwaukee at some point. Who knows how old this pipe really is.
Posted: Fri May 11, 2012 11:13 am
by swimmingfree
was this pipe made for the spree or did some one modified it to fit??? do you have a tack on that spree ??? i wonder if you put the other pipe on it if it wood lose speed or tork ?? in short dose that pipe help??
Posted: Fri May 11, 2012 11:20 am
Posted: Fri May 11, 2012 11:25 am
by Force4000
swimmingfree wrote:was this pipe made for the spree or did some one modified it to fit??? do you have a tack on that spree ??? i wonder if you put the other pipe on it if it wood lose speed or tork ?? in short dose that pipe help??
The pipe was factory made to fit the spree, all original welds in good shape, nothing chopped or cut. It has more top end then anything, without a tune on old gas my spree only did like 25-26mph, now with this pipe on the same gas and same tune, (waiting to finally run it out of gas to tune on fresh gas) I was hitting 28-30mph and my buddy who weighs like 15 pounds less then me got it over 30 on like a mile straight away. Did seem to a loose a little on the bottom end with it but its not tuned yet so cant say for sure.
Posted: Fri May 11, 2012 11:33 am
by swimmingfree
not sure how old the gas is but ever spring when i get it up and running i run prem gas for the first tank or two to help clean out the carb and tank some people use sea fom in steed..
Posted: Fri May 11, 2012 11:36 am
swimmingfree wrote:not sure how old the gas is but ever spring when i get it up and running i run prem gas for the first tank or two to help clean out the carb and tank some people use sea fom in steed..
Using Sta-bil in the tank in the fall would solve that issue and the regular use of Seafoam would keep the carb clean. Proper maintenance prevents these problems rather than having to fix them.
Posted: Fri May 11, 2012 11:52 am
by swimmingfree
i drain all the gas out of my toys ever the carb in the fall and do the same for the snow blower in the spring .. but that me and im difrent
the stable and sea fome is a good thing to do and it dose help a lot !!!! i wish more people ( my brothers ) wood do it ..
Posted: Sat May 12, 2012 10:26 pm
by Red Eft Performance
Well that's a decent looking pipe! Nice score.By far the best spree pipe I've seen. Guess I'm surprised this thread hasn't gotten more attention.
