Page 1 of 2
Run Then Dies
Posted: Sun May 14, 2006 12:22 am
by hondanoob
ok so i just got spree from a friend and he hadden run it in about a year. so i get new gas oil and a plug. after a few kicks players and luck it starts. i let it idle for about a minute. then i give it a little gas. it then almost dies i let off the gas and it goes back to running at idle. i also race go karts and i had remembered one day at the track my yamaha kt 100 motor did the same thing. we tried everything. we had somehow come to find that when i stuck my hand over the air intake it ran great. first we thought a vacume leak. nope that wasnt it. it was about 50 degrees that day and we finaly figures out it was fuel separation from oil. and that the gas had some water in it. so back to the honda. i remembered that so i tried covering the intake and by golie it worked. it ran great. i took the air box off and stuck a paper towel into the air intake and it ran pretty good. i took it out and it wont move. i changed the gas and still the same thing. what do u guys think it is?
Posted: Sun May 14, 2006 1:00 am
by MySpree
dirty carborator
Posted: Sun May 14, 2006 1:11 am
by nextalcupfan
i had the same thing happen to me it wold only run with my hand over the carb intake. got carb cleaned and that fixed it
by hondaman
Make sure you have a clean air filter or install a new one.
Posted: Sun May 14, 2006 1:14 am
by MySpree
or re oil the old one...
Posted: Sun May 14, 2006 3:54 pm
by myhonda
ha yea i remember doin tyhat with my spree for like a month. it would only run if i rode around with my hand over the carb keepin it runnin
Posted: Sun May 14, 2006 5:10 pm
by hondanoob
so tell me what to do to my carb please?!
Posted: Sun May 14, 2006 5:50 pm
by hondaman
Take it off the bike. Take it apart and clean the entire inside with carburetor cleaner. Unscrew the main jet and make sure you see light through the holes. Use liberal amounts of carb cleaner and make sure it is spotless inside the carburetor. The key word here is clean. clean, clean.
Posted: Sun May 14, 2006 6:43 pm
by hondanoob
ok thanks
Posted: Sun May 14, 2006 9:00 pm
by MySpree
adn re oil the air filter or if its old get a new one... there cheap
Posted: Mon May 15, 2006 12:41 pm
by hondanoob
ill try it out today. and why should u even run the air filter as long as u dont go into like dusty areas
Posted: Mon May 15, 2006 3:17 pm
by hondaspree86er
because there is always going to be dirt on the road and it could get sucked in the carb
Posted: Mon May 15, 2006 6:48 pm
by MySpree
and because it sorta quiets teh engine...
Posted: Tue May 16, 2006 5:25 pm
by Farfignugin
also...you wouldnt want something like a small pebble or something getting (somehow, ya never know) sucked into the carb....that would be REALLY bad....
Posted: Tue May 16, 2006 7:22 pm
by bowman2
What settings do you guys use for the idle? And what setting do you use for the air/fuel mixture?
