Will I fry my by with a stock pipe???
Mrcrabapple
Post by Mrcrabapple »
Ahhhhhhh can't find a pipe quite yet and I'm going on a long ride sat... If this a bad idea?? :werd:
01 ELITE SR
Polini 72cc bbk
Kelli variator
Jap light
28mm oko
CT mani
Polini medium torque spring
9:1 gears (in da mail)
3m carbon fiber vinyl
Stock pipe!!!-- pg long soon?!?!?!
& Stock zuma for the woman
Mrcrabapple
I'm not running the ct mani and 28mm yet.... Its ready to go on.... But without an aftermarket pipe- should I just leave the stock carb on for now?
01 ELITE SR
Polini 72cc bbk
Kelli variator
Jap light
28mm oko
CT mani
Re: Will I fry my by with a stock pipe???
Mrcrabapple wrote:I'm not running the ct mani and 28mm yet.... Its ready to go on.... But without an aftermarket pipe- should I just leave the stock carb on for now?
I just built a 72cc engine and used a stock pipe.
It still goes 59mph.
http://www.hondaspree.net/phpBB3/viewto ... =1&t=22353
devenex
Post by devenex »
28mm carb seems quite large for stock pipe, but would probably work if you're set on swapping.
I'd just keep the stock carb if it was my scoot since most the gains of the bigger carb won't be realized without a pipe to match (its best to tune/derestrict intake and exhaust together).
Instead of stressing about this right now why not just enjoy riding your scooter amd keep breaking in the bore until you get the money for a pipe? :coolcruise:
Before doing the long ride though, it would be smart to do some plug chops to make sure you have the right jetting.
1986 Spree w/ '87 SE50 motor
Mrcrabapple
Plug chops??
01 ELITE SR
Polini 72cc bbk
Kelli variator
Jap light
28mm oko
CT mani
evilone
Post by evilone »
Mrcrabapple wrote:Plug chops??
Try using the search button towards the top. There has got to be tons of info on plug chops.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
