Is this elite variated?
Posted: Thu May 17, 2012 1:25 pm
by deuce217
I found this elite for 500.00 it is whiteand gray. 1988 with 2500 miles. here is a pic of the kick cover, the tranny code is AF05E. Is this variated? Is it worth 500$? And a 2.5 hour drive? Image
Re: Is this elite variated?
Posted: Thu May 17, 2012 1:39 pm
by Downsouthdio
Yes variated.. If its running and with title i think its a good deal :thumbwink:
Posted: Thu May 17, 2012 1:40 pm
by eliteguy50
Yes, it is variated. Looks like an Elite LX. Good deal depends on the body and your total fuel cost too.
Posted: Thu May 17, 2012 1:41 pm
by Fishman43
Ask them to take $50 off the price so you can get a new airbox :smile:
Posted: Thu May 17, 2012 1:58 pm
by deuce217
Are there many aftermarket parts for this? Is it the same as the aero 50 motor? If so those seem hard to find good parts for..
Posted: Thu May 17, 2012 2:02 pm
by Fishman43
I did the Ruckus variator on my Aero, a bore kit from Daywot on Ebay, and a Leo Vince pipe, plus a slightly larger rear tire and hit 48mph on a slight down hill with a full tuck. I regularly cruize around at 40mph with no issue. Getting the carb tuned was the most tedious task since small increment jets are hard to source.
Posted: Fri May 18, 2012 10:11 am
by Feral_Sparky
Fishman43 wrote:I did the Ruckus variator on my Aero, a bore kit from Daywot on Ebay, and a Leo Vince pipe, plus a slightly larger rear tire and hit 48mph on a slight down hill with a full tuck. I regularly cruize around at 40mph with no issue. Getting the carb tuned was the most tedious task since small increment jets are hard to source.
Believe it or not, but my stock '87 elite se50 when I had it tuned right and the weather was warm, it would hit 42mph all day long and even hit 45 a couple times, but once the weather was anything but perfect, it was back to 35mph for the rest of the year.
Posted: Fri May 18, 2012 1:44 pm
by Fishman43
I believe it, but the time it took me to get too speed VS what it does now are night and day and LOADS more fun!!!
Posted: Fri May 18, 2012 2:24 pm
by deuce217
Thats mobbin on a stock scooter! I am not gonn buy this one. The drive... and it is not that clean.
Posted: Fri May 18, 2012 2:25 pm
by deuce217
Thanks for the help guys!
Posted: Sat May 19, 2012 10:14 am
by elitedio
...and it has some sort of electrical problem.
Posted: Sat May 19, 2012 1:39 pm
by veedubh20
do dio swap. :thumbwink:
Posted: Sat May 19, 2012 5:14 pm
by deuce217
elitedio wrote:...and it has some sort of electrical problem.
Did you buy it?
