af18e spree vs af16 dio
bakaracer
Re: af18e spree vs af16 dio
Post by bakaracer »
thats because your friend has stock 12to1 gears
bakaracer
Post by bakaracer »
graphite9 wrote:Do you think a 24mm Carb is big enough for my setup?
yeah its fine.
bakaracer
Post by bakaracer »
what exhaust are you using? what bore?
kingkamehameha
Post by kingkamehameha »
My spree didnt like lighter weights. Im running all 8.5s right now.
fastplastic
Post by fastplastic »
72cc to 125cc hmm maybe there would be a difference in weights :nerd:
fastplastic
unless your port the crap out of the 82 the polini will always make more power... its just how it is...
fastplastic
looks like a v8 pipe good lil torque pipe.... just because the polini is 72cc doesnt mean 82cc is gonna be bigger faster better out of the box...
Red Eft Performance
Post by Red Eft Performance »
Your rollers weights might be too light. My friend has 50mm bore 28 carb pg long 9.1 gears and the 7g rollers are Way too light. The polini is going to rev higher than your bore. Your bore will be better off at a lower rpm. Try heavier weights.
Red Eft Performance
View products click => Here
Mystic
Post by Mystic »
If I am not mistaken that is a yms r1 pipe
deuce217
Post by deuce217 »
Have you checked out your spark plug? What is the gap? Nice wheels!
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
fastplastic
Mystic wrote:If I am not mistaken that is a yms r1 pipe
I belive you are correct
Mystic
Post by Mystic »
those pipes come in 26mm or 28mm maybe bigger not sure
dv/dt
Post by dv/dt »
When i had my polini bore on the stock gears it pulled insanely hard for a scoot, but it was game over at 45mph. I never got sick of the acceleration though!
Then i put 8.44s in and it still pulls, but not as hard as before obviously.
2000 Elite: oko 24 (45/135), corsa, pg short, keli vari, 8.44 secondaries = 71mph gps
1995 Jog
2004 Malaguti F15
2007 Ducati Monster S4r
bakaracer
Re: Re: af18e spree vs af16 dio
Post by bakaracer »
graphite9 wrote:
deuce217 wrote:Have you checked out your spark plug? What is the gap? Nice wheels!
Replaced my plug, ill check the gap when i get home. I think his just pulls so much harder cause of the gears. He's on stock gears right now. So is the r1 pipe any good? r1 sounds familiar now.
that pipe is fine. whats your jetting at? do you know if the boost port is matched to that bore?
bakaracer
Post by bakaracer »
graphite9 wrote:I'm not sure about the porting. I'm running a 120 main and a 44 pilot. Pretty sure I'm too fat up top. I'm tempted to pull it apart and slap a poling kit on it. I don't know how it was broken in, or how the porting was done. Throttle response is awesome, its real snappy, it just seems like it should accelerate better. Accelerating at 2/3 throttle is the same as full throttle.
Have you done a plug chop? find out first if the block has been ported to match the bore your using before you buy a polini. yeah the 50-51mm bores are mainly more for mini stroke crank setups. there are some that is for stock stroke but most I see now are for mini stroke cranks.the only way to know if yours is for a stock stroke is do a port map of it. the numbers will tell.
