clutch housing question
zenmaster222
Post by zenmaster222 »
Ok I got a question I have a 01 elite sr I just got my keli vari in the mail haven't quite got to the point of putting it on yet....but I got a little problem the rubber that fits around the metal clutch cover is stretched and fell off when takeing the metal piece off my scoot and isn't tight enough to go back on the grooves. Sorry this might sound confusing I don't know the proper terms and names but am learning...sooo is it ok to ride with the cover off I see some of your highly modded scooters with it off but want to make sure this is ok and wont hurt anything.. is there anything I should do while riding with it off or be aware of thanks for all and any advice :smile:
evilone
Re: clutch housing question
Post by evilone »
Leaving it off will keep things cooler. I haven't heard any negatives about leaving it off..
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
zenmaster222
Ok cool thank you yeah I will probly put it on but am sure the rubber will have to be ordered at the dealership
bonesv
Post by bonesv »
The oil and gas that drips into that area causes the gasket to become larger
and seemingly impossible to re-install properly. You don't want any debris or moisture
in the clutch/drive belt area, especially oil and/or gas.
To reduce that possibility, I have used black rtv sealant to seal it up when no cash was available to buy a new one.
Hope this is helpful to you.
Happy Trails! :happy:
zenmaster222
Yes that does help I think I will order the gasket but might do a little test cruising with it off so when people run it without the clutch cover do you just need to periodically check for moisture or gas/oil
If the hoses off the carb vent are router properly you will not get any gas or oil on anything except the ground.
bonesv
Post by bonesv »
zenmaster222 wrote:Yes that does help I think I will order the gasket but might do a little test cruising with it off so when people run it without the clutch cover do you just need to periodically check for moisture or gas/oil
I would say yes, check often. Use some drain line on the overflow nipple from the carburetor.
Use caution when motor is running, the belt is easily accessible, and probably no riding in the rain or off road would also be a suggestion.
zenmaster222
Awe I see thank you that makes sense
