clutch housing question
Posted: Sat May 26, 2012 3:57 am
by zenmaster222
Ok I got a question I have a 01 elite sr I just got my keli vari in the mail haven't quite got to the point of putting it on yet....but I got a little problem the rubber that fits around the metal clutch cover is stretched and fell off when takeing the metal piece off my scoot and isn't tight enough to go back on the grooves. Sorry this might sound confusing I don't know the proper terms and names but am learning...sooo is it ok to ride with the cover off I see some of your highly modded scooters with it off but want to make sure this is ok and wont hurt anything.. is there anything I should do while riding with it off or be aware of thanks for all and any advice
Re: clutch housing question
Posted: Sat May 26, 2012 9:31 am
by evilone
Leaving it off will keep things cooler. I haven't heard any negatives about leaving it off..
Posted: Sat May 26, 2012 3:42 pm
by zenmaster222
Ok cool thank you yeah I will probly put it on but am sure the rubber will have to be ordered at the dealership
Posted: Sat May 26, 2012 5:41 pm
by bonesv
The oil and gas that drips into that area causes the gasket to become larger
and seemingly impossible to re-install properly. You don't want any debris or moisture
in the clutch/drive belt area, especially oil and/or gas.
To reduce that possibility, I have used black rtv sealant to seal it up when no cash was available to buy a new one.
Hope this is helpful to you.
Happy Trails!
Posted: Sat May 26, 2012 6:25 pm
by zenmaster222
Yes that does help I think I will order the gasket but might do a little test cruising with it off so when people run it without the clutch cover do you just need to periodically check for moisture or gas/oil
Posted: Sat May 26, 2012 6:49 pm
If the hoses off the carb vent are router properly you will not get any gas or oil on anything except the ground.
Posted: Sat May 26, 2012 6:51 pm
by bonesv
zenmaster222 wrote:Yes that does help I think I will order the gasket but might do a little test cruising with it off so when people run it without the clutch cover do you just need to periodically check for moisture or gas/oil
I would say yes, check often. Use some drain line on the overflow nipple from the carburetor.
Use caution when motor is running, the belt is easily accessible, and probably no riding in the rain or off road would also be a suggestion.
Posted: Sat May 26, 2012 7:29 pm
by zenmaster222
Awe I see thank you that makes sense
