need help on jetting start point.
Have a 44.1 mini stroked 50mm PG bore, PG Long, and 28 mm OKO Carb. (Builds in signature)I'm looking for a start point with my jetting. I was way over jetted trying to cool my high compression now, I have no clue what sizes to order. I have pilots 50-60 and mains 145-158. Thanks
2001 Elite,50mm bbk, 44.1 mm mini stroker
28mm oko carb, no restriction air filter, ct intake
zx clutch, polini for ruckus vari, pg long, 7.7 gears
1999 Elite 51mm bbk, oko vari, sef ramp plate, 8.44 gears
Re: need help on jetting start point.
55 pilot 140 main air fuel screw 2 turns out needle clip middle. try it with the 145 you got and see if thats to rich first.
I'm running 145 now its to rich from 1/2 throttle to full throttle ther really isn't any speed gain and my rpms are maxing out 8k. but if I'm cruzing in 1/4 to 1/2 throttle range temps get up in the 360'sbakaracer wrote:55 pilot 140 main air fuel screw 2 turns out needle clip middle. try it with the 145 you got and see if thats to rich first.
- Trafficjamz
360 is good right?
[quot e="Trafficjamz"]360 is good right?
[/quote]
I should have clarified 360 and still climbing I pull over and idle back down
- Trafficjamz
guen84 wrote:I should have clarified 360 and still climbing I pull over and idle back downTrafficjamz wrote:360 is good right?
What is your compression at?
125 got a PG kit from VT made for mini stroke this piston was way shorter than any other kit I've had...Trafficjamz wrote:guen84 wrote:I should have clarified 360 and still climbing I pull over and idle back downTrafficjamz wrote:360 is good right?
check for a air leak and make sure the compression is 125. use the kick lever and not the electric start to check that. also make sure your not using a long hose and a adapter for the compression tester. it adds volume to the head so compression readings will be lower
not this time ive already blown up 3 cylinders this is solid, i can tell compression is down and no air leaks. last build pilot was 58 pilot and main was 160...bakaracer wrote:check for a air leak and make sure the compression is 125. use the kick lever and not the electric start to check that. also make sure your not using a long hose and a adapter for the compression tester. it adds volume to the head so compression readings will be lower
- Trafficjamz
what pipe?
How many psi do you think the hose and adaptor adds?
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
the is no information about the crank case port or untouch porting...
that is the reason why you went blow up 3 cylinders...
crankcase need to clean out real good.
any metal shaving lay on the bottom crank case... from seize bore. any metal shaving damage crank, crank bearings...
PG LongTrafficjamz wrote:what pipe?
kit 1 was compression, kit 2 compression (turned out the gauge was bad), kit 3 air leak from exhaust flangeveedubh20 wrote:the is no information about the crank case port or untouch porting...
case is cut to match
any metal shaving lay on the bottom crank case... from seize bore. any metal shaving damage crank, crank bearings...after each time case has been split, cleaned, and new bearings
- Trafficjamz
Madman wrote:bakaracer wrote:check for a air leak and make sure the compression is 125. use the kick lever and not the electric start to check that. also make sure your not using a long hose and a adapter for the compression tester. it adds volume to the head so compression readings will be lower
Adds negative 10lbs or so
