1988 SA50 motor into a 1985 Spree?
clement235
Hello,
Will a 1988 SA50 motor go into a 1985 Spree fairly easily?
Thanks for any advice.
- SpreeMadness520
Re: 1988 SA50 motor into a 1985 Spree?
First of all, There was no sa50 engine in 1988. If the engine is an sa50 it is from a 1994-2001 honda elite 50, Yes it will fit in the spree but there is a few fabrications that need to be made first. Great swap if you have access to machinery like welders and other equipment
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
clement235
http://motorscooterguide.net/Honda/Elit ... eSA50.html
According to these guys SA50's started in 1988.
I have an 88 SA50 they came with the variated AF05E. Not 100% if the engine will swap? Do you have them both? Give it a shot
Sent from my MB855 using Tapatalk 2
1988 Honda Elite LX - AF05E w/ 65cc Malossi MHR, OKO24, CT Manifold, UNI Filter, Ruckus Variator, Custom DIY Briggs & Stratton Exhaust, Met Front & Rear Wheels, 95mm Front Brake Conversion
- SpreeMadness520
Hmm? didnt know that
learn something new every day lol
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
clement235
- swimmingfree
yes but you need to make a motor mount and move the shock..
Sounds like you had SA50 and AF16 mixed up.SpreeMadness520 wrote:Hmm? didnt know thatlearn something new every day lol
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- SpreeMadness520
Exactly what happened evilone haha
130cc Stroker
1984 Porsche 944
1965 Vespa
1984 Porsche 944
1965 Vespa
Look through this thread:
http://www.hondaspree.net/phpBB3/viewto ... =16&t=6536
1986 Spree w/ '87 SE50 motor
clement235
Thanks for that link!
- kingkamehameha
First of all there is no welding or machinery needed. I did the swap on my little lanai with just basic tools. Trafficjamz made a write up on how to modify a 87 elite mount to fit perfect and it is very easy to do. The shock mount is just a hole drilled tru the frame with a m10x140 bolt that goes through it. You can tack weld it in place if you need to but i didnt. The spree stator can be used with the sa50 mag so that wiring is plug and play. The only issue i had was my huge rear tire rubbing on my mud flap after the swap
- kingkamehameha
viewtopic.php?f=4&t=16097&hilit=+Se50+mount+spree
This should be made a sticky so i dont have to dig it up every time someone does the swap
Thanks kingkamehameha and devenex. Agreed, we have been pointing members to links for a while.
Rather than another sticky, SA50->Spree will become a 'wiki topic soon.
- kingkamehameha
Great haha. There is many ways to do it but i prefer the most simple and solid way. Ive seen some hacked up motor mount set ups! Doing it tjams way ensures a straight wheel angle too
