Page 1 of 2
1988 SA50 motor into a 1985 Spree?
Posted: Thu May 31, 2012 7:31 am
by clement235
Hello,
Will a 1988 SA50 motor go into a 1985 Spree fairly easily?
Thanks for any advice.
Re: 1988 SA50 motor into a 1985 Spree?
Posted: Sat Jun 02, 2012 4:52 pm
by SpreeMadness520
First of all, There was no sa50 engine in 1988. If the engine is an sa50 it is from a 1994-2001 honda elite 50, Yes it will fit in the spree but there is a few fabrications that need to be made first. Great swap if you have access to machinery like welders and other equipment
Posted: Sun Jun 03, 2012 7:40 am
by clement235
Posted: Sun Jun 03, 2012 4:59 pm
by smokindon
I have an 88 SA50 they came with the variated AF05E. Not 100% if the engine will swap? Do you have them both? Give it a shot
Sent from my MB855 using Tapatalk 2
Posted: Sun Jun 03, 2012 5:03 pm
by SpreeMadness520
Hmm? didnt know that
learn something new every day lol
Posted: Sun Jun 03, 2012 6:15 pm
by clement235
Posted: Sun Jun 03, 2012 8:14 pm
by swimmingfree
yes but you need to make a motor mount and move the shock..
Posted: Sun Jun 03, 2012 8:45 pm
by evilone
SpreeMadness520 wrote:Hmm? didnt know that
Sounds like you had SA50 and AF16 mixed up.
Posted: Mon Jun 04, 2012 9:52 pm
by SpreeMadness520
Exactly what happened evilone haha
Posted: Fri Jun 08, 2012 6:19 pm
by devenex
Posted: Mon Jun 18, 2012 1:53 am
by clement235
Thanks for that link!
Posted: Mon Jun 18, 2012 2:37 am
by kingkamehameha
First of all there is no welding or machinery needed. I did the swap on my little lanai with just basic tools. Trafficjamz made a write up on how to modify a 87 elite mount to fit perfect and it is very easy to do. The shock mount is just a hole drilled tru the frame with a m10x140 bolt that goes through it. You can tack weld it in place if you need to but i didnt. The spree stator can be used with the sa50 mag so that wiring is plug and play. The only issue i had was my huge rear tire rubbing on my mud flap after the swap
Posted: Mon Jun 18, 2012 2:44 am
by kingkamehameha
viewtopic.php?f=4&t=16097&hilit=+Se50+mount+spree
This should be made a sticky so i dont have to dig it up every time someone does the swap
Posted: Mon Jun 18, 2012 2:52 am
Thanks kingkamehameha and devenex. Agreed, we have been pointing members to links for a while.
Rather than another sticky, SA50->Spree will become a 'wiki topic soon.
Posted: Mon Jun 18, 2012 3:15 am
by kingkamehameha
Great haha. There is many ways to do it but i prefer the most simple and solid way. Ive seen some hacked up motor mount set ups! Doing it tjams way ensures a straight wheel angle too
