Page 1 of 3
Looking for 70cc polini big bore advice
Posted: Sun Jun 03, 2012 2:32 pm
by spree picker
I have a 2001 elite I bought that already has the kit.whats is the best spark plug to run and were should the idle air screw be set at
Re: Looking for 70cc polini big bore advice
Posted: Sun Jun 03, 2012 6:05 pm
by veedubh20
need to get ngk b8hs.
what you plan to run on the motor setup?
Posted: Sun Jun 03, 2012 6:24 pm
by spree picker
It's already set up carb,intake reads and polini belt variator and red clutch spring and v8 pipe
Posted: Sun Jun 03, 2012 6:39 pm
by veedubh20
just run 32:1 premix.
Posted: Sun Jun 03, 2012 10:18 pm
by scottinscotty
i'm still running my oil injection... and love it! ... i wouldn't recommend on pre-mixing 32-1 .. but that's up to you!
Posted: Sun Jun 03, 2012 10:20 pm
by scottinscotty
and if it has the stock carb.. i'd probably go with a b9hs i would buy a bigger carb though, the pilot jet in your stock carb is migty small for that cylinder and you may risk seizure when you let off the throttle after a long wot. run!
Posted: Sun Jun 03, 2012 10:25 pm
by scottinscotty
i'd start with 1 & 1/4 turns out on the idle air scew..
Posted: Sun Jun 03, 2012 11:37 pm
by Trafficjamz
scottinscotty wrote:i'm still running my oil injection... and love it! ... i wouldn't recommend on pre-mixing 32-1 .. but that's up to you!
How does your oil pump run to your ct mani? did you tap a second hole?
I wouldn't dare run the stock oil pump on my 72cc polini.
It can only mix the oil and gas at about 70:1
Posted: Sun Jun 03, 2012 11:40 pm
by Trafficjamz
spree picker wrote:I have a 2001 elite I bought that already has the kit.whats is the best spark plug to run and were should the idle air screw be set at
The idle should be set so that the tire does not spin while on the centerstand.
Posted: Mon Jun 04, 2012 1:14 am
by scottinscotty
Taped a second hole.... I've put almost 2000 miles on my kit with the stock oil pump...
Posted: Thu Jun 07, 2012 12:12 am
by ottoman
Everyone has their own idea on oil ratios and if it works great!
I run 42.5:1
Why 42.5:1? Because I am lazy and thats 3 oz per gallon. Run it in everything from my weed wacker to my drag scooters and never had a lube related failure.. not saying I never wrecked anything but that always came down to operator error
Posted: Thu Jun 07, 2012 1:35 am
by bakaracer
spree picker wrote:It's already set up carb,intake reads and polini belt variator and red clutch spring and v8 pipe
What carb,manifold and reeds are you using?
Posted: Mon Jun 18, 2012 5:20 pm
by spree picker
21mm
Posted: Mon Jun 18, 2012 5:45 pm
by kingkamehameha
scottinscotty wrote:Taped a second hole.... I've put almost 2000 miles on my kit with the stock oil pump...
Do not use the stock pump its asking for trouble
Posted: Mon Jun 18, 2012 10:37 pm
by spree picker
It's Plugged
