RED 86 Spree MAKEOVER
shadow7117
Post by shadow7117 »
Hi I am Brandt and I am a EET student at Purdue. I love honda scooters some past scooters I fixed up were Elite, Ruckus, and Spree. So I bought this Honda 1986 Honda Spree about a year and I am still working on it. It has 5684 miles I bought it off a guy on craigslist for $65. Now I am up at college and restoring it in my free time so I will have a little ride for getting around on campus. Here is a timeline of pictures of its progress.
Then I did ton of body work and painting. Also I did a base coat of flex primer to ensure the top coat would stay on with the plastic flexing.
Didn't have the air box hose so I made this.
Just about to put the new seat cover on it.
This is the aftermarket ignition I installed on it.
This is what it looks like with all the body panels just slapped on it(not screwed on).
So far I have installed a new starter motor, honed the cylinder walls, cleaned the carbs, repainted it, rewired it, throttle assembly, key ignition, coil, and front+rear brake cables.
I use to be able to get the scooter to start up with the kick start but then it would die soon after.(I think the problem their is the air box, I need a lid for it). Also the starter motor I bought isn't even trying to turn over the engine. I think something is wrong electrically with it.
1st I want to get the scooter to be able just to kick start. So is anyone selling an air box lid or know of some other option that works great.
2nd After the scooter is able to kick start then I will deal with the starter motor.
Also my blog has more pix of my progress on the scooter.http://www.tumblr.com/blog/theprojectboy
Check out all of my projects: http://theprojectboy.tumblr.com/
____________________________________________________________
'07 Honda Ruckus
'86 Honda Spree NQ50
Honda Spree NQ50
Honda Elite E SB50P
Honda Urban Express
patthesoundguy
Re: 1986 NQ50 Honda Spree
Post by patthesoundguy »
I like the clear hose from the carb to the airbox, just get a hose clamp on the carb end and you will be set. The clear hose looks really cool :2thumbs:
devenex
Post by devenex »
Don't know if you took it off or its missing but you need to make sure the cooling fan is installed before running it, otherwise the top end will heat seize.
1986 Spree w/ '87 SE50 motor
Hope that's not the new seat cover ripped at the seam. Great shop in INDY, that Two Wheels... :thumbwink: ...Bill Eberle runs the place and was always helpful with my projects during my Indy residence. Next time you have Monical's pizza, think of me.... :geekdance:
donut
Post by donut »
motormike wrote:Hope that's not the new seat cover ripped at the seam. Great shop in INDY, that Two Wheels... :thumbwink: ...Bill Eberle runs the place and was always helpful with my projects during my Indy residence. Next time you have Monical's pizza, think of me.... :geekdance:
monical's...yummy thin crust memories....
'86 Aero 50 (NB50)
'01 Yamaha Jog Nextzone
shadow7117
That is the old seat cover and also I am working on getting a cooling fan + cover. I will have to check out that shop in indy.
'07 Honda Ruckus
Honda Spree NQ50
Honda Elite E SB50P
Honda Urban Express
shadow7117
I recently purchased the fan and I just put on the new seat cover.
Now all I need is fan cover, air box lid, and install the rear brake cable I have.
Also need to paint the wheels + Engine Cover(probably flat black or green) and I might install these LED bulbs into the headlight once everything is done.
The horn on it doesn't work or it is not their so I think it would be awesome to get a horn like this:
'07 Honda Ruckus
Honda Spree NQ50
Honda Elite E SB50P
Honda Urban Express
shadow7117
patthesoundguy wrote:I like the clear hose from the carb to the airbox, just get a hose clamp on the carb end and you will be set. The clear hose looks really cool :2thumbs:
I am glad someone appreciated the clear hose. Hey by chance where can I get a hose clamp? just go to a hardware store?
'07 Honda Ruckus
Honda Spree NQ50
Honda Elite E SB50P
Honda Urban Express
You need to get the actual rubber hose that goes there or you will have an air leak and the scooter will run like crap.
And get a horn too. :smile:
shadow7117
So is the name of it air hose? Do you know of anyone selling one? I couldn't find it on ebay.
'07 Honda Ruckus
Honda Spree NQ50
Honda Elite E SB50P
Honda Urban Express
abreen89
Post by abreen89 »
I have the hose rubber hose from the carb to the air filter box, i also have a horn and fan cover. pm me with an offer.
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
ILLEGALLIFESTYLZ311
Re: RED 86 Spree MAKEOVER
Post by ILLEGALLIFESTYLZ311 »
no if you go to autozone and buy a tube of gaskit maker and put some around where the hose mates with the airbox, it should be pretty airtight
-90mph, 50mpg, still laughing?-
ILLEGALLIFESTYLZ311 wrote:no if you go to autozone and buy a tube of gaskit maker and put some around where the hose mates with the airbox, it should be pretty airtight
just get the correct part
there are plenty of people on this site that can hook you up with that tube for cheap.
thekingof7
Post by thekingof7 »
You seem to like pushing part sales. Just an observation.
I just like to see things done correctly.
The smallest air leaks can cause these small engines to run badly and overheat.
This is a blown engine waiting to happen.
There are lots of people on this forum with the correct parts....... why half * your build, when it can be done right?
