Aero to spree
dirtbikemikebike
Aero to spree
Post by dirtbikemikebike »
Will an Aero motor fit into a Spree ? Will it fit nicely, or is there some modification to be made?
That's a good swap. It will fit, you need to do some rework to the motor mount.
mopedman
Post by mopedman »
yea you have to swich engine mounts
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
darat
Post by darat »
psh EZ
Rabbi
Post by Rabbi »
what motor did the Aero come with?
I ask because I'm in the process of fitting a Dio SR motor (AF18) to my 1980 Spree. The mounts are definately different... I think I will have to cut the Dio mount and weld the Spree mount onto it.
Did you ever get to finishing this project?
It would be sweet if you had some tips for me! :)
MySpree
Post by MySpree »
well the elite engine is diff then th aero, the bolts were diff sezes
Rabbi
Post by Rabbi »
Are they both AF18E motors though?
darat
Post by darat »
umm i didnt know that sprees were made in 1980 they were made from 84 to 87
hrnytrtlsgsxr
Post by hrnytrtlsgsxr »
Rabbi wrote:Are they both AF18E motors though?
thye af18e motor is a dio motor not an aero motor
Rabbi
Post by Rabbi »
In New Zealand they are not called the same names thats why I'm asking.... what motor does the Aero have?
Rabbi
Post by Rabbi »
darat wrote:umm i didnt know that sprees were made in 1980 they were made from 84 to 87
mine is a 1980... its called a Nifty Fifty here in New Zealand. It looks just like a Spree, but it doesnt have those reflector things on the front wheel arch
darat
Post by darat »
oh ok..
hrnytrtlsgsxr
the aero should have a af05 motor which is the older version of the motor we call the dio now.Parts from the af05 motor can actually fit on a dio motor.
ryan.ott
Post by ryan.ott »
Can you put dio parts (bore kits) on the af05
darat
Post by darat »
there the same as the se50 bore kit so yeah.. the highest that they have is a 65cc and that is a huge difference..
