SPREE flooding/
SPREE flooding/
hi, i just bought two 1986 sprees, one of them is flooding alot . its got great spark,compression and it obviosley getting fuel, but why is there so much. I tested it with a carb from a running spree and it still flooded????
Re: SPREE flooding/
sounds to like your petcock is not shutting off. does it flood the floor when it sits?
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
Re: SPREE flooding/
The only way the bad petcock would cause fuel on the floor or flood the engine is if the needle and seat in the carb was also bad.
Re: SPREE flooding/
no it doesnt flood the floor, it only really flood when i try starting it, and thats usually after i let it sit and air out with no plug or exhaust.
Re: SPREE flooding/
Then there is nothing wrong with the petcock. The needle and seat in the carb is bad.Bspree wrote:no it doesnt flood the floor, it only really flood when i try starting it, and thats usually after i let it sit and air out with no plug or exhaust.
Re: SPREE flooding/
alright so buy a new needle, and what is the seat like a seal or somthing?
Re: SPREE flooding/
http://hondaspree.net/wiki/index.php5?t ... Valve_SeatBspree wrote:alright so buy a new needle, and what is the seat like a seal or somthing?
Oh and the service manual so you can find this stuff out on your own.
http://www.hondaspree.net/phpBB3/viewforum.php?f=11
Re: SPREE flooding/
wait that cant be rigth, i put a carb from a completly fine running spree on there and it still flooded out ?
Re: SPREE flooding/
Then You have something else wrong.Bspree wrote:wait that cant be rigth, i put a carb from a completly fine running spree on there and it still flooded out ?
Re: SPREE flooding/
well could it be the reeds or a stuck float??
Re: SPREE flooding/
Hm-m-m, when you say "flooding out", what exactly is happening - fuel flowing out onto the ground - only when starting, fuel flooding the crankcase?
A bad petcock means the fuel flows whether or not there is vacuum (engine cranking or running) - if the valve seat and valve needle are in good shape this may go un-noticed because it will stop the flow. This is one of the reasons most folks like clear fuel lines.
A bad valve seat or needle can usually be remedied by cleaning - the toothpaste method using a q-tip works wonders. These are the typical culprits if fuel is flowing out the carb overflow tube onto the ground.
If the engine is getting flooded, what is the symptom you are experiencing? How does the plug look?
'83 Aero NH80
'87 Elite SE50
'70 CT90
'72 CT90
'73 CT90
'74 CT90
'83 Aero NH80
'87 Elite SE50
'70 CT90
'72 CT90
'73 CT90
'74 CT90
Re: SPREE flooding/
This belongs in the Tech help section.
Re: SPREE flooding/
the plug is saoked and the bottom end is filled with gas so i had to turn it on its side to drain the gas, could it be the reeds, becaquse the carb came off a runnning spree
Re: SPREE flooding/
No, the reeds can never cause this, extra fuel is entering the system either thru the carb or the petcock thru the vacuum line.Bspree wrote:the plug is saoked and the bottom end is filled with gas so i had to turn it on its side to drain the gas, could it be the reeds, becaquse the carb came off a runnning spree
- patthesoundguy
Re: SPREE flooding/
Fuel has to come from somewhere. Bear is right petcock is likley blame by leaking fuel down the vacum line pull both lines off of the carb and see how much fuel comes out of either line. If there is no vacum on the vacum line no fuel should flow out of the petcock if its still good. Fuel comming out of the vacum line would bypass the carb obviously.
