Need help! Crank removal
Hello, i searched wiki but it wasnt very clear. I split the case on my 87 se50p. How do i remove the crank? (hit with a hammer???) I need to clean debris out of the crankcase.
Thank you!
Thank you!
1985 Spree AF16: viewtopic.php?f=20&t=31053
2001 Elite Daily: viewtopic.php?f=16&t=31397&p=272223#p272223
- Trafficjamz
Re: Need help! Crank removal
You can use a steering wheel puller and some spare bolts.Ben L. wrote:Hello, i searched wiki but it wasnt very clear. I split the case on my 87 se50p. How do i remove the crank? (hit with a hammer???) I need to clean debris out of the crankcase.
Thank you!
Read this
http://www.hondaspree.net/phpBB3/viewto ... =3&t=21752
Thank you, that side is off. I need to remove the transmission side so the crankshaft is completely removed.
- Trafficjamz
Your bearings are stuck to the crank You will need a separator tool.
Rhet...how does that get get the crank out of case?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- Trafficjamz
The steering wheel puller can pop the crank out of either side.
The separator tool will be the next tool the op will need.
- kingkamehameha
Usualy cranks come out with the bearings still on them. You need the bearing puller to take off the old bearings so the crank can be re used. The people who arent planning on using the stock crank dont really need the toolevilone wrote:Rhet...how does that get get the crank out of case?
Thanks everybody, my steering wheel pullers doesn't look like it will do the job on the tranny side so I might have to modify it. Thanks for the bearing separator tool info as well, that would be my next question.
get a new crank. bearing and seals.
Thanks everyone for the help. I just removed the crank completely! I had to make some brackets to get the steering wheel puller to mount the tranny cover. Next on my list is purchasing a bearing remover tool.
