1984 Honda spree starter issue
lovemyelite50
- Goped
Hello, I have an 84' spree. When I go to start it and it starts, the starter hangs over and keeps spinning until I shut it off and start it again. But after I start it again the starter still stick for 5 seconds
Re: 1984 Honda spree starter issue
Dirty or in need of lube bendix
lovemyelite50
- Goped
I don't understand....
- paulpauly7
the bendix will be dirty it needs cleaning and a lube
lovemyelite50
- Goped
What's the bendix?
The kick starter's internal mechanism. Remove the kick starter arm, take the transmission belt case off and disassemble the kicker gears so you can give the bushes and shafts a good degrease and clean up. Ask what is a suitable grease/lubricant to repack and assemble the kicker (dry-lube, lithium grease...any suggestions here guys?)
lovemyelite50
- Goped
I took out and thuroly cleaned it, and it still does it.
That is because the kick starter has nothing to do with it. The electric starter bendix is your problem. Look it up in the manual.lovemyelite50 wrote:I took out and thuroly cleaned it, and it still does it.
