1984 Honda spree starter issue
Posted: Fri Jun 15, 2012 11:54 pm
by lovemyelite50
Hello, I have an 84' spree. When I go to start it and it starts, the starter hangs over and keeps spinning until I shut it off and start it again. But after I start it again the starter still stick for 5 seconds
Re: 1984 Honda spree starter issue
Posted: Sat Jun 16, 2012 12:51 am
Dirty or in need of lube bendix
Posted: Sat Jun 16, 2012 12:53 am
by lovemyelite50
I don't understand....
Posted: Sat Jun 16, 2012 1:04 am
by paulpauly7
the bendix will be dirty it needs cleaning and a lube
Posted: Sat Jun 16, 2012 1:06 am
by lovemyelite50
What's the bendix?
Posted: Sat Jun 16, 2012 6:00 pm
by geezer101
The kick starter's internal mechanism. Remove the kick starter arm, take the transmission belt case off and disassemble the kicker gears so you can give the bushes and shafts a good degrease and clean up. Ask what is a suitable grease/lubricant to repack and assemble the kicker (dry-lube, lithium grease...any suggestions here guys?)
Posted: Sat Jun 16, 2012 6:34 pm
by lovemyelite50
I took out and thuroly cleaned it, and it still does it.
Posted: Sat Jun 16, 2012 8:37 pm
lovemyelite50 wrote:I took out and thuroly cleaned it, and it still does it.
That is because the kick starter has nothing to do with it. The electric starter bendix is your problem. Look it up in the manual.
