1985 Spree problems... please help...
Posted: Thu May 18, 2006 10:33 pm
by drl33t
i have a spree and i have been having some problems getting it to run right. my lattest broblem is that when i lay into the throttle, it will 'bog' down and try to die unless i let off the thottle. i have jerryrigged a air tube and made a air filter out of some foam, i have also cleaned the carb very well and have done a bunch of other cleaning to it but this problem is still with me.
i can get it to run right when i hold and adjust my fingures over the carb to get it right. when i do that it runs great!
so now i am looking for a factory air hose and factory air filter it solve the problem of no back pressure because that is what i think it is. so if anybody has theas parts, a price would be great and if anybody has any other sugestion on what the proplem might be would be great too! thanks
Posted: Thu May 18, 2006 10:37 pm
by -aL-
id have to say its definatly your jerry rigged air filter set up, id go for the factory set up...
Posted: Fri May 19, 2006 12:34 am
by noiseguy
It's your filter setup causing the issue. Contact Greg at uspmale@yahoo.com or check the parts for sale board.
Posted: Sat May 20, 2006 1:09 am
by drl33t
well, i have good news, i mostly fixted the air prob by using ducttape and a washer to make the hole smaller... so it now works better but i still want to try to ure the stock parts...
i will try a contact greg or if anyone else has the part, please let me know... thakx
oh yea, i also need a mirror so i can look behind me if nayone canhelp me out...
