SYM DD50, Will it need a new crank?
Meejacob
Post by Meejacob »
Hey guys, so recently i a recieved a 82cc 54mm Prodigy Bore w/ head, and a Kuka pipe from a friend. My question is will i need to get a new crank to be able to run it? I dont have a lot of cash so im slowly buying things atm. CT mani, Oko carb, and 7:1 gears would be coming first. Any help is greatly appreciated guys, Thanks.
veedubh20
Re: SYM DD50, Will it need a new crank?
Post by veedubh20 »
YES! get a new crank/bearings/ seals! Honda parts only!.
Sell the dd50 motor!
get a af16 motor or af18 motor. if you can find who sell af18 japan motor.
Meejacob
Post by Meejacob »
Yeah ive been lurking on craigslist for a af16 for a while now. What size crank should i go with? thinking about mini stroking it. New to the moped scene so probably gonna stick with the dd50 for now and scoop up an AF block later on.
kingkamehameha
Post by kingkamehameha »
Ive got a bare af16 block no stripped bolt holes and in really good shape. 100 plus shipping from big island
veedubh20
Post by veedubh20 »
why go mini stroker crank? just hassle to make new gaskets, play around port timing windows. tdc and bdc. crank piston stroked .
it had to to be done right at the first time!
waste times mini stroker crank.
If you like go fast, why spend money on dio big stroker 125cc.
get a jog! imo :2thumbs:
Meejacob
Post by Meejacob »
Hmm i see what you mean, ill probably just get new bearings and seals for now. Should be buying the CT mani and Oko carb beginning of next week. What size oko should i get? Its a 54mm bore w/ 50.5mm head (what the box says). Idk how im gonna get the old manifold off yet, some type of rivet or something on it. Ill try get pics for you guys.
veedubh20
Post by veedubh20 »
a vise grip.
Meejacob
Post by Meejacob »
Dont know why i didnt try that before, thanks haha. I noticed you live Oahu, where do you usually buy your parts from?
