Shipping rates - what am I doing wrong
breaze
Post by breaze »
Obviously, I don't ship that often. Selling a muffler to someone here on the forum. I boxed it up - weighs 7 1/2 pounds, box is 25 x 17 x 9. Got on USPS to print a label and the shipping cost was at $50.00 - only offered express and priority - both right around $50.00. This is from Atlanta, GA to Portland, Oregon.
Checking further, it looks like I can use their flat rate large package (if I can find one) and send it for around $15.00.
Either I'm doing something wrong or they really want you to use their boxes.
'83 Aero NH80
'87 Elite SE50
'70 CT90
'72 CT90
'73 CT90
'74 CT90
Re: Shipping rates - what am I doing wrong
Post by eliteguy50 »
Click on "other" next to priority. It takes longer (about a week) but it should be about $15 for shipping.
Chicago Ben
Post by Chicago Ben »
ground usps flat rate should be the cheapest
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
As long as the box doesn't exceed a Girth + Length value of 84", $15 sounds about right for Parcel Post at 8 pounds. Pack the snot out of it so it doesn't rattle, and tape a cardboard tube over the stinger tip (if any) so dropping it on the end doesn't punch the stinger into the canister.
Dio89Elite
Post by Dio89Elite »
Yes, they really do want you to use their boxes! :confused: :shock: :surprise: :sad: :crazy:
We have it worse to and from the 50th state :nervous: :sad:
Good options/info from the other members tho (for alternative shipping options) :) :mrgreen:
