Missing fuel valve
Posted: Thu Dec 30, 2004 9:59 pm
by spree13
I just pulled my "new" '85 Spree apart and the previous owner has tossed the stock vacuum fuel valve and put in a cheesy looking petcock. Is this future trouble? I would like to keep it close to stock. Should I bother tracking a factory valve down and installing it? I've got a lead on some parts Sprees locally that I'm going to check out Monday, maybe a good valve there. What's everyones thoughts on this?
Posted: Fri Dec 31, 2004 12:47 am
by noiseguy
The stock valves like to stick. Go to tech docs for the fix (soak in gas.) If the scooter is a kludge job, you may want to concentrate on more pressing issues, and leave this for last. I'd make sure you're running an inline filter with it, the guy may have removed the tank filter.
Spree redo!
Posted: Sun Jan 02, 2005 9:33 pm
by spree13
Noiseguy, you're right, there are more pressing things on this Spree. After a fairly deep teardown I have found, no air filter element, holes drilled on the top and a non stock ill fitting carb to airbox connector. No wonder this thing idled real fast! The starter is toast, stinks like it's burned up, no battery, no clamps on the fuel lines, a drive belt with chunks missing. The fellow I bought it from is a machinist and to start it he made up a T key to put in a 1/2 drill and a matching nut on the end of the crank. The bendix was removed and a hole drilled in the belt cover to access crank nut. Believe it or not this worked. Not real practical but functional! :lol: He did give me the OE crank nut and bendix so I'll get a starter and battery and return it to stock. I'm sure I'll have carb issues after putting the stock filter system back!
Posted: Sun Jan 02, 2005 11:27 pm
by noiseguy
Ack. 8O Fix the aircleaner first. Email drichardson@core.com with a list of parts you need. Tell him we sent you.
