How does cylinder size affect power
- ILLEGALLIFESTYLZ311
- Goped
Im not trying to offend anyone here but how does the difference of a cylinder affect the power?. More CC= Power correct?
-90mph, 50mpg, still laughing?-
Re: How does cylinder size affect power
Bigger boom equals bigger power.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
There is no replacement for displacement, is the old saw. That being said, a well tuned 72 motor will out power a poorly tuned 82 motor.
- Red Eft Performance
Sure size has an effect but with these little motors port timing is king. Most of the the large Taiwan bores have junk port timing. Also remember the motor was designed for 50cc so bigger cc requires more modification/porting to the block to take advantage of the extra displacement.
Red Eft Performance
View products click => Here
- Goped
those were my thought also just checkingRed Eft Performance wrote:Sure size has an effect but with these little motors port timing is king. Most of the the large Taiwan bores have junk port timing. Also remember the motor was designed for 50cc so bigger cc requires more modification/porting to the block to take advantage of the extra displacement.
an old school trick is to match the crank to the bore.
More BS from the scooter world's biggest liar.maddog wrote:an old school trick is to match the crank to the bore.
