1985 Spree... Timing issue?
- 87spree70superbee
Okay. See the video to see what I'm talking about. If anyone can help me solve this problem, it would be greatly appreciated. I have no idea what's wrong.
http://youtube.com/watch?v=1pGBdf6BszAE
-Nick
-Nick
Black 85 Spree-SOLD
Red 87 Spree... Ended up buying the same one mentioned below.
I started riding my uncle's 87 Spree at the drag strip when I was 8...
It's easier to stop caring three years ago than it is to fix it in present time.
Re: 1985 Spree... Timing issue?
Spark trigger coil alignment is preset, and has no adjustment. If the spark is off in timing a likely suspect is the flywheel to crank timing is off. A sheared or missing key can allow large timing mis-alignment from stock. Pull the flywheel and inspect, BTW good vid of the issue
- Trafficjamz
the timing being off would not cause it to crank like that.
is there less resistance to ground at the starter motor when the kill switch is on?
- 87spree70superbee
Okay, so... Remove the fan and the metal thing behind it? I'm still amousewheels wrote:Spark trigger coil alignment is preset, and has no adjustment. If the spark is off in timing a likely suspect is the flywheel to crank timing is off. A sheared or missing key can allow large timing mis-alignment from stock. Pull the flywheel and inspect, BTW good vid of the issue
Black 85 Spree-SOLD
- 87spree70superbee
Trafficjamz wrote:the timing being off would not cause it to crank like that.
How would I check for that? I have a multimeter...
Black 85 Spree-SOLD
- Trafficjamz
87spree70superbee wrote:Trafficjamz wrote:the timing being off would not cause it to crank like that.
put the Multimeter setting on Ohms.
Put one lead on the batteries' negitive terminal and on on the starter motors' green wire.
It should read zero (or close to it) Flip the run/kill switch and repeat the test.
Dont try to remove the flywheel with out the proper tool.
This is not a timing issue.
- swimmingfree
did you or some one ever tack off the fly wheel???? it the thing with the fan on it..
- 87spree70superbee
Trafficjamz wrote:87spree70superbee wrote:Trafficjamz wrote:the timing being off would not cause it to crank like that.
Alright. I'll try it later. Thanks for the help, and don't worry, I won't pull the flywheel.
Black 85 Spree-SOLD
- 87spree70superbee
I pulled the fan off when I cleaned everything, never pulled the flywheel.swimmingfree wrote:did you or some one ever tack off the fly wheel???? it the thing with the fan on it..
Black 85 Spree-SOLD
- swimmingfree
im not saying that the other are wrong at all but there is a key way in the crank and fly wheel if its not in there it may be what going on ..
have you ever had it running????
- 87spree70superbee
Yeah, I had it running, it actually ran when I bought it. Ran pretty well until last week. Then this started up. I'm going to save the flywheel pulling for last. I'll try everything else first, I don't want to f- with the flywheel, lolswimmingfree wrote:im not saying that the other are wrong at all but there is a key way in the crank and fly wheel if its not in there it may be what going on ..
Black 85 Spree-SOLD
- swimmingfree
because it was running i wood try what the other said as well..
That is a classic timing issue. I'm with mouse, flywheel key would be my first guess and if that it good, a bad CDI could cause this.
Definitely NOT a starter issue,
Def the way to go - rule out anything easy and starter ground is easy to check out.Yeah, I had it running, it actually ran when I bought it. Ran pretty well until last week. Then this started up. I'm going to save the flywheel pulling for last. I'll try everything else first, I don't want to f- with the flywheel, lol
- Trafficjamz
Bear45-70 wrote:That is a classic timing issue. I'm with mouse, flywheel key would be my first guess and if that it good, a bad CDI could cause this.
why would a bent flywheel key make it stumble like that?
And why would having the kill switch on or off make a difference?
This is a two stroke , so valves are not opening or closing.
why would this not be a starter issue?
A bad ground to the starter would make it stumble
The kill switch being on could be making a better path to ground.
