Page 1 of 4
1985 Spree... Timing issue?
Posted: Mon Jul 02, 2012 11:00 pm
by 87spree70superbee
Okay. See the video to see what I'm talking about. If anyone can help me solve this problem, it would be greatly appreciated. I have no idea what's wrong.
http://youtube.com/watch?v=1pGBdf6BszAE
-Nick
Re: 1985 Spree... Timing issue?
Posted: Mon Jul 02, 2012 11:07 pm
Spark trigger coil alignment is preset, and has no adjustment. If the spark is off in timing a likely suspect is the flywheel to crank timing is off. A sheared or missing key can allow large timing mis-alignment from stock. Pull the flywheel and inspect, BTW good vid of the issue :)
Posted: Tue Jul 03, 2012 3:48 am
by Trafficjamz
the timing being off would not cause it to crank like that.
is there less resistance to ground at the starter motor when the kill switch is on?
Posted: Tue Jul 03, 2012 9:55 am
mousewheels wrote:Spark trigger coil alignment is preset, and has no adjustment. If the spark is off in timing a likely suspect is the flywheel to crank timing is off. A sheared or missing key can allow large timing mis-alignment from stock. Pull the flywheel and inspect, BTW good vid of the issue :)
Okay, so... Remove the fan and the metal thing behind it? I'm still a :newb: . Jeez, I have only had the bike for two weeks, an oil pump and who knows what now...
Posted: Tue Jul 03, 2012 9:56 am
Trafficjamz wrote:the timing being off would not cause it to crank like that.
How would I check for that? I have a multimeter...
Posted: Tue Jul 03, 2012 10:41 am
by Trafficjamz
put the Multimeter setting on Ohms.
Put one lead on the batteries' negitive terminal and on on the starter motors' green wire.
It should read zero (or close to it) Flip the run/kill switch and repeat the test.
Dont try to remove the flywheel with out the proper tool.
This is not a timing issue.
Posted: Tue Jul 03, 2012 11:13 am
by swimmingfree
did you or some one ever tack off the fly wheel???? it the thing with the fan on it..
Posted: Tue Jul 03, 2012 11:47 am
Alright. I'll try it later. Thanks for the help, and don't worry, I won't pull the flywheel. :-)
Posted: Tue Jul 03, 2012 11:49 am
swimmingfree wrote:did you or some one ever tack off the fly wheel???? it the thing with the fan on it..
I pulled the fan off when I cleaned everything, never pulled the flywheel.
Posted: Tue Jul 03, 2012 12:03 pm
by swimmingfree
im not saying that the other are wrong at all but there is a key way in the crank and fly wheel if its not in there it may be what going on ..
have you ever had it running????
Posted: Tue Jul 03, 2012 1:45 pm
swimmingfree wrote:im not saying that the other are wrong at all but there is a key way in the crank and fly wheel if its not in there it may be what going on ..
Yeah, I had it running, it actually ran when I bought it. Ran pretty well until last week. Then this started up. I'm going to save the flywheel pulling for last. I'll try everything else first, I don't want to f- with the flywheel, lol
Posted: Tue Jul 03, 2012 1:47 pm
by swimmingfree
because it was running i wood try what the other said as well..
Posted: Tue Jul 03, 2012 2:12 pm
That is a classic timing issue. I'm with mouse, flywheel key would be my first guess and if that it good, a bad CDI could cause this.
Definitely NOT a starter issue,
Posted: Tue Jul 03, 2012 3:04 pm
Def the way to go - rule out anything easy and starter ground is easy to check out.
Posted: Wed Jul 04, 2012 1:08 am
by Trafficjamz
Bear45-70 wrote:That is a classic timing issue. I'm with mouse, flywheel key would be my first guess and if that it good, a bad CDI could cause this.
why would a bent flywheel key make it stumble like that?
And why would having the kill switch on or off make a difference?
This is a two stroke , so valves are not opening or closing.
why would this not be a starter issue?
A bad ground to the starter would make it stumble
The kill switch being on could be making a better path to ground.
