Help with first minarelli build =)
Downsouthdio
Re: Help with first minarelli build =)
Post by Downsouthdio »
Spmotostore.com
Honda super dio
Corsa
26mm
Sparrow
Mystic
Post by Mystic »
I am about to start working on a 04 or 05 zuma myself :D
Downsouthdio
Im on my 4th now.. Spmoto and scootercraft both ship fast and have lots of parts for these motors n scoots..i hit 64 on my old school vertical zuma.. It pulled on my first elite hard up top :wink:
Honda super dio
Corsa
26mm
Sparrow
graphite9 wrote:So, Im thinking of going one of two ways. either a kit like this
stage 6 with stage 6 crank
http://www.SPMOTOSTORE.COM/product_p/s6-7516602.htm
or something like this.
I don't know if the h20 cooled setup is worth it.
i thought the goal was just 55mph?
the AC polini kit can do that.
Downsouthdio
They are torque monsters so even a contessa will get you what your looking for.. Over range kit will make it yank hard
Honda super dio
Corsa
26mm
Sparrow
Mystic
Post by Mystic »
contesta is made for stock crank
Downsouthdio
You can use stock crank
Honda super dio
Corsa
26mm
Sparrow
Post by eliteguy50 »
We need to know what your 01 motor came from. Is it a vertical or a horizontal minarelli? Both can be made to pull hard but the parts are different. The '01 horizontal engines were made with Taiwan cranks. I would replace that just to be safe. They are known for breaking at higher RPMs.
veedubh20
Post by veedubh20 »
dont get a stage6 crank, I heard they break!
get a polini crank and polin bearings. got on my motor 3,000 miles on it trouble free! I get 60mph gps with a stock carb 14mm LOL :rock:
Downsouthdio
If your not doing a real agressive cylinder n just want 55 with acceleration dont even swap your crank..
Honda super dio
Corsa
26mm
Sparrow
Downsouthdio
Mopedsplus.net has universal water pumps fans and radiators
Honda super dio
Corsa
26mm
Sparrow
eliteE85
Post by eliteE85 »
a liquid cooled kit will always have more hp do to the lower temp- that is suggesting the same pore and same porting on both air and liquid model- i did a conversion on a vento triton- that bike was a rocket ship
