smaller slot style main jets vs larger hex main jets
Posted: Wed Jul 18, 2012 11:53 pm
by Chicago Ben
Hey guys,
My Keihin pwk runs these smaller (shorter) style 'slot style'/unscrew with a flat head type main jets and I'm wondering if running the larger (taller) hex style main jets are ok to run. Will they hit or interfere with the float bowl? Is this just a matter of running a different imulsion tube or what?
Re: smaller slot style main jets vs larger hex main jets
Posted: Wed Jul 18, 2012 11:55 pm
by Chicago Ben
Height difference appears to be 8mm slot type vs. 16.5mm hex type
Posted: Thu Jul 19, 2012 9:34 am
by Chicago Ben
wow - check out this PDF file I found talking about the differences in the two styles... if you care to learn that is
http://www.ozebook.com/compendium/t500_files/mikuni.pdf
Posted: Thu Jul 19, 2012 9:40 am
by Chicago Ben
So here is what I found out according to this PDF file:
If your carb (according to this dudes crazy research) came stock with the small "reverse/slotted" style mains, you cannot sub with any other jet type. But on the flip side, if your carb came stock with a hex type you can sub with other jet styles but you may need to modify the neeedle jet body to make everything work correctly
see page 3 of pdf file
Posted: Thu Jul 19, 2012 9:53 am
by Chicago Ben
someone may want to put this on wikispeedia...
