Re: 150cc gy6 elite bolt in kit build
Posted: Mon Jul 23, 2012 11:23 am
by dv/dt
looks way good! Take lots of pics!
Posted: Wed Jul 25, 2012 2:24 am
by dv/dt
that subframe looks great! good job
Posted: Wed Jul 25, 2012 2:29 am
by Trafficjamz
does the gas tank still fit?
How does the seat attach?
Posted: Wed Jul 25, 2012 12:17 pm
by Trafficjamz
looks good
keep up the good work
Posted: Wed Jul 25, 2012 1:41 pm
by tru72
Awesome job brah!!!!
Posted: Fri Jul 27, 2012 12:34 am
by bradthreee
How hard is the wiring? Are you going to be selling the subframe?
Posted: Fri Jul 27, 2012 1:11 pm
by LMH
Use the good ole gravity bleed. Open up the reservoir cap and then open your bleeder. If it doesnt bleed still there is a kink or an obstruction. Blow some compressed air thru the master line if you think its blocked. It probably wont unblock it but it will let you know its clogged.
How much are you thinking the sub frame will be? I have an extra 88 elite and 2 gy6 150s here. One has a 196cc jug on it even. Worse thing is no kick starters on them and cdi is ran off of battery too, so if you have a weak battery youre screwed.
Keep us up to date on the pricing.
Posted: Mon Jul 30, 2012 5:39 pm
by ottoman
Well I like to ride my GY6 powered Elite more than either of my 2 stroke Elites. More usable off the line torque... better mileage and no pre mixing.
A friend like driving it so much we are putting a GY6 in his Zuma this weekend.
Posted: Sun Aug 05, 2012 2:30 pm
by Trafficjamz
graphite9 wrote:Running a 30mm oko 48/138. Sputters at 1/2-3/4 throttle. Gotta dial in the jetting.
Sent from my DROID RAZR using Tapatalk 2
why did you change the carb?
Posted: Sun Aug 05, 2012 3:26 pm
by veedubh20
the main jet go down 135
Posted: Mon Aug 06, 2012 2:02 pm
by spkrboxx
If you start making these I would be very interested!!!
Anyone ever do a bigger front wheel conversion to make it look more even?
Posted: Wed Sep 26, 2012 11:28 pm
by ottoman
I agree they are a blast to ride with the stock GY6 150. We just GPS'd a Zuma we put a GY6 into and it went 57 mph with a stock motor, cheap stock replacement pipe (quiet) and a open style air filter.
The guy loves it!!
We also put one into a Elite with similar results... neither guy wants to go back to the 2 strokes they replaced.
Your going to have a hard sell on this forum because they are pretty diehard 2 stroke fans.. but to each his own.
