Auto bystarter
Posted: Thu May 25, 2006 3:13 pm
by h2guy
wondering what the procedure for testing the bystarter is. If there is a way to see if it's bad or not. I'm just wondering if that's what's causing my greif.
Posted: Thu May 25, 2006 9:35 pm
by MySpree
hook it up to a 12 volt battery, wait about 10 mins and the needle should come out..
Posted: Fri May 26, 2006 1:27 am
by dirtbikemikebike
So, the needle drops down after its warmed up. If my Spree runs fine, but has problems giving it throttle, could it be the bystarter not droping ?
Posted: Fri May 26, 2006 11:43 am
by noiseguy
dirtbikemikebike wrote:So, the needle drops down after its warmed up. If my Spree runs fine, but has problems giving it throttle, could it be the bystarter not droping ?
No. That's an airbox problem or vaccuum leak.
Posted: Tue May 30, 2006 3:03 pm
by h2guy
can you hook the bystarter up to a car battery or will that burn it up?
Posted: Wed May 31, 2006 3:35 am
by jbarb
It will be fine, 12 volts is 12 volts. It will only draw the power it needs.
Posted: Wed May 31, 2006 12:18 pm
by eman916
Also check to see if the O ring on bystarter is good. I had a worn O ring on my 84 Aero and it had a hard time starting. Went to Home Depot and got a #10 O ring from thier plumbing department and now my scooter starts everytime!
