Best carb for corsa on dio.????
Posted: Thu Jul 26, 2012 11:15 pm
by Simonsr50
Ok I'm buying a corsa for my elite and need a carb. I want the stock airbox and want to use stock oil injection. I also want plug and play as far as chock and cables go. What do I get? I'm thinking a 19mm just want to know best one and easiest to install with stock look.
Re: Best carb for corsa on dio.????
Posted: Thu Jul 26, 2012 11:33 pm
by veedubh20
get a mikuni vm 18mm carb. work on the stock airbox.
need to made adaptor. , the carb is clamp intake.
you will need a gear kit and keli pulley.
8:1 gear. .
19mm dellorto carb. need a rubber hose to airbox.
stock intake boot will not work on dellorto carb. mikuni 18mm carb.
Posted: Fri Jul 27, 2012 12:32 am
by Simonsr50
Now what about cables? Also, do you think it's a bad idea to do this with the corsa? I def way stock exhaust and would like stock airbox but if the best and most reliable way is to do like a 24mm I might. What are your opinions? Also what carb is best for bolt and go with cables choke and everything in 1 kit?
Posted: Fri Jul 27, 2012 12:53 am
by bakaracer
you dont always have to run a big carb. a 18mm carb will work fine and using the stock exhaust will work fine too.
Posted: Sat Jul 28, 2012 6:52 pm
by kingkamehameha
I like the stealth mode. I would go with the 8.44:1s if i was gonna build something that wasnt being taken past 55 they are good all around gears.
Posted: Fri Aug 03, 2012 8:16 pm
by maddog
The keihin 28mm is the best along with a ct intake with a stock modded air filter, you can do an oko 24mm or a polini 19mm with mods.
