Trailtech TTO CHT (Cylinder head temp) Gauge acting goofy
Chicago Ben
Post by Chicago Ben »
Anybody else with Trailtech TTO CHT gauge have theirs act up?
mine will go blank aka no sensor is hooked up, then read temps way off, then read correct temps, then go blank, then go to way off temps again...
All my lines are connected fine , sensor ring is clean and secure...
Thinking about picking up a backlit KOSO gauge off amazon to replace this unit... edit here --- looks like koso's slim line only reads upto 248 F, dang...
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
abreen89
Re: Trailtech TTO CHT (Cylinder head temp) Gauge acting goof
Post by abreen89 »
maybe a low battery?
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
LMH
Post by LMH »
You have a connection thats grounding out or losing signal it sounds like. If it hits as high as it can read its being grounded out. Could be a faulty sender wiring or the unit itself. You could shake the wiring harness while sitting still and see if it causes it to go blank or read crazy.
Also check the wiring routing. Harnessing the temp sensor close to coil output wire or stator excitor wire could cause a noisy signal.
the sending units are garbage.
all of mine have gone out.
the tiny cht gauge from trailtech seems to work better.
LMH
Post by LMH »
I think hes talking about the tiny cht gauge, the tto cht is pretty small and not bad on price. I have noticed their send units dont last long(bend or go out of round) if youre doing a lot of plug chops.
Chicago Ben
Trafficjamz wrote:the sending units are garbage.
yeah that seems to be the issue here - when you say tiny... which one are you talking about? My TTO is the smallest gauge they make I believe
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
bonesv
Post by bonesv »
Hey Ben, I think it is the normal operating mode for that particular unit. I have one on my daily rider and it flashes the max. temp every 6 seconds, then goes back to current temps. I think it says this also on the package. Have not had any other issues so far since May of this year. Of course I heard all the cons about them but it is not my experience so far. Hope that helped you and glad your scoot is back on the road!!!
Chicago Ben
bonesv wrote:Hey Ben, I think it is the normal operating mode for that particular unit. I have one on my daily rider and it flashes the max. temp every 6 seconds, then goes back to current temps. I think it says this also on the package. Have not had any other issues so far since May of this year. Of course I heard all the cons about them but it is not my experience so far. Hope that helped you and glad your scoot is back on the road!!!
No, I know tto displays current then displays max every 5-6 or so. I'm saying it will display null, then temps wayyy off
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
abreen89
Post by abreen89 »
is it in celsius mode? here is how to change modes.. http://trailtech.net/tto_temperature.html
these things run off batteries my buddy had one and it was giving him trouble and "glitching" as he called it replaced the battery and it was all good there not alot that can go wrong with these little units
sorry thought you were talking about the vapor gauge. :oops:
Chicago Ben
dang the sender units go out on their vapor units?
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Chicago Ben
abreen89 wrote:is it in celsius mode? here is how to change modes.. http://trailtech.net/tto_temperature.html
no it's just goofy - might just buy a new one
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
abreen89
Post by abreen89 »
your choice but a 2$ batter is cheaper then a 40$ unit
