honda Spree Carb to intake manifold bolt threads?
Moparmick
Post by Moparmick »
Anyone have any ideas on how to rethread carb to intake safely? On a spree , I have 3 different carbs and all have 1 or both bolt holes stripped, cant get air tight seal between carb and intake,having trouble getting it to run, found this as the only obvious problem, any help appreciated. Thanks, Mick
martynkim
Re: honda Spree Carb to intake manifold bolt threads?
Post by martynkim »
Moparmick wrote:Anyone have any ideas on how to rethread carb to intake safely? On a spree , I have 3 different carbs and all have 1 or both bolt holes stripped, cant get air tight seal between carb and intake,having trouble getting it to run, found this as the only obvious problem, any help appreciated. Thanks, Mick
Heilcoil or nuts on the back side of the carb. Then again, :happy: new carb.
Helicoil, Timesert or other repair is a good repair, but may cost a bit if the owner has to buy the set.
On the Spree, if threads on the bystarter side are stripped, a 'jam nut' is an easy fix, but requires care with bolt length. The bolt must not come in contact with the bystarter side housing. Add washers or grind as required.
-- Hazard --
When the bolt hits the housing, it can/will distort the bore the bystarter air valve (outer brass collar) has a close slide fit with. Distortion of the carb body freezes up the bystarter .
-- Alternate low cost repair --
Some have drillled/tapped for 1/4 x 20 threads.
-- Pics of jam nut repair --
A screwdriver will hold the nut if a thin 10mm wrench is not handy.
abreen89
Post by abreen89 »
in my expierence the heli coil is really hard to use on the carb because the thread holes arent deep enough the nut works the best..
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
paulpauly7
Post by paulpauly7 »
tap it out to a m7 and get new bolts
abreen89
Post by abreen89 »
paulpauly7 wrote:tap it out to a m7 and get new bolts
you risk cracking the carb and then you will have to get a new one
paulpauly7
ive done lots i suppose if your a meathead and cant use a tap correctly then i suppose that would be a problem
abreen89
Post by abreen89 »
paulpauly7 wrote:ive done lots i suppose if your a meathead and cant use a tap correctly then i suppose that would be a problem
is m7 jus next size up?
paulpauly7
yes the stock bolts are m6
abreen89
Post by abreen89 »
paulpauly7 wrote:yes the stock bolts are m6
so wouldnt that require drilling up for the m7 too fit?
paulpauly7
just stick to your bolts :peace:
fastplastic
Post by fastplastic »
jam nut works well but number 7 drill bit and 1/4-20 tap works to.... m7 isnt to common in the states but should work
abreen89
Post by abreen89 »
fastplastic wrote:jam nut works well but number 7 drill bit and 1/4-20 tap works to.... m7 isnt to common in the states but should work
good too know i might do this myself someday
yamahauler660r
Post by yamahauler660r »
I got a m6 (stock bolt size) helicoil kit from autozone for $28. you just need a drill and a 1/4" drill bit. or send the carbs to me for $2 a hole + shipping
My 2 wheeled bikes:
99 Elite S
97 Z50R
96 Elite S
89 Elite E x2
86/96 "Spree S/SpreElite"
87 Elite
86 Spree x4
86 Spree Special
85 Spree x3
84 Spree
83 Aero 80
80 XL250S
71 Trail 70 H
