honda Spree Carb to intake manifold bolt threads?
Posted: Fri Aug 03, 2012 9:50 pm
by Moparmick
Anyone have any ideas on how to rethread carb to intake safely? On a spree , I have 3 different carbs and all have 1 or both bolt holes stripped, cant get air tight seal between carb and intake,having trouble getting it to run, found this as the only obvious problem, any help appreciated. Thanks, Mick
Re: honda Spree Carb to intake manifold bolt threads?
Posted: Fri Aug 03, 2012 9:53 pm
by martynkim
Moparmick wrote:Anyone have any ideas on how to rethread carb to intake safely? On a spree , I have 3 different carbs and all have 1 or both bolt holes stripped, cant get air tight seal between carb and intake,having trouble getting it to run, found this as the only obvious problem, any help appreciated. Thanks, Mick
Heilcoil or nuts on the back side of the carb. Then again,
new carb.
Posted: Fri Aug 03, 2012 11:18 pm
Helicoil, Timesert or other repair is a good repair, but may cost a bit if the owner has to buy the set.
On the Spree, if threads on the bystarter side are stripped, a 'jam nut' is an easy fix, but requires care with bolt length. The bolt must not come in contact with the bystarter side housing. Add washers or grind as required.
-- Hazard --
When the bolt hits the housing, it can/will distort the bore the bystarter air valve (outer brass collar) has a close slide fit with. Distortion of the carb body freezes up the bystarter .
-- Alternate low cost repair --
Some have drillled/tapped for 1/4 x 20 threads.
-- Pics of jam nut repair --
- Spree_Carb.jpg (72.36 KiB) Viewed 7586 times
A screwdriver will hold the nut if a thin 10mm wrench is not handy.
- SpreeCarb_JamNut_Screwdriver.JPG (43.19 KiB) Viewed 7586 times
Posted: Fri Aug 03, 2012 11:49 pm
by abreen89
in my expierence the heli coil is really hard to use on the carb because the thread holes arent deep enough the nut works the best..
Posted: Sat Aug 04, 2012 1:36 am
by paulpauly7
tap it out to a m7 and get new bolts
Posted: Sat Aug 04, 2012 1:53 am
by abreen89
paulpauly7 wrote:tap it out to a m7 and get new bolts
you risk cracking the carb and then you will have to get a new one
Posted: Sat Aug 04, 2012 1:59 am
by paulpauly7
ive done lots i suppose if your a meathead and cant use a tap correctly then i suppose that would be a problem
Posted: Sat Aug 04, 2012 2:07 am
by abreen89
paulpauly7 wrote:ive done lots i suppose if your a meathead and cant use a tap correctly then i suppose that would be a problem
is m7 jus next size up?
Posted: Sat Aug 04, 2012 4:34 pm
by paulpauly7
yes the stock bolts are m6
Posted: Sat Aug 04, 2012 8:41 pm
by abreen89
paulpauly7 wrote:yes the stock bolts are m6
so wouldnt that require drilling up for the m7 too fit?
Posted: Sat Aug 04, 2012 11:22 pm
by paulpauly7
just stick to your bolts
Posted: Sat Aug 04, 2012 11:29 pm
by fastplastic
jam nut works well but number 7 drill bit and 1/4-20 tap works to.... m7 isnt to common in the states but should work
Posted: Sun Aug 05, 2012 12:12 am
by abreen89
fastplastic wrote:jam nut works well but number 7 drill bit and 1/4-20 tap works to.... m7 isnt to common in the states but should work
good too know i might do this myself someday
Posted: Sun Aug 05, 2012 10:32 am
by yamahauler660r
I got a m6 (stock bolt size) helicoil kit from autozone for $28. you just need a drill and a 1/4" drill bit. or send the carbs to me for $2 a hole + shipping
