Will a elite clutch fit a minarelli?
I was wondering if the clutch offa af16 will fit this 03 zuma I have if I reuse the zuma clutch bell?? Having trouble finding a replacement at a price I can afford and it started making a whistling noise and i can feel a vibration in the scooter sorta like the belt slipping since I rode double yesterday
Re: Will a elite clutch fit a minarelli?
Check the transmission input shaft and bearing.
Telltale sign is wobbly clutch (you will be able to move it by hand).
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
- Downsouthdio
wont work!!!
dude you need to get a vino, jog clutch will work 2 shoes is 105mm.
If I gotta buy a new clutch I am just going to upgrade to a new rear pully and 107mm 3 shoe clutch
The rear pully sheaves where the belt rides is pitted badly by rust so it is eating my belt up
