Spree with an AF16E Electrical compatibility question
Posted: Mon Aug 06, 2012 8:39 pm
by yamahauler660r
I'm finishing my swap project (86 spree with a 96 elite S engine)
will this setup work?
spree:
harness, ICM (CDI), voltage regulator, and resistor.
Elite S:
stator & flywheel, coil
Can I use a spree/elite E regulator(the big style), and are the spree and elite E&S ICM/CDI all the same?
Re: Spree with an AF16E Electrical compatibility question
Posted: Mon Aug 06, 2012 8:57 pm
by fastplastic
Match ur wire colors and ur good to go no jbig deal everything is the same
Posted: Tue Aug 07, 2012 5:42 am
by kingkamehameha
Use the spree stator or you will blow your headlights. No wire splicing or anything plug and play
Posted: Tue Aug 07, 2012 6:31 am
by yamahauler660r
So that's why my tested headlight doesn't work on it. Thanks for the info. I'll definetly switch to a spree setup along with another headlight.
Posted: Tue Aug 07, 2012 12:08 pm
by Trafficjamz
kingkamehameha wrote:Use the spree stator or you will blow your headlights. No wire splicing or anything plug and play
I know the you had a problem with yours......but most of the spree dio swaps we do around here work out just fine with the elite stator.
Maybe
your setup blows the head lights cause it revs so high.
Posted: Tue Aug 07, 2012 12:13 pm
by yamahauler660r
Can I put some sort of rectifier or anything between the stator and headlight?
Posted: Tue Aug 07, 2012 12:20 pm
by fastplastic
Dude u have nothing to worry about I'm been running mine for a long time with an elite stator with no problems....
Posted: Tue Aug 07, 2012 5:16 pm
by yamahauler660r
Ok thanks guys. Maybe the headlight never worked. I only had it running for a short time before the reeds had a catastrophic failure.....due to a reed block issue
I've also changed the stator and flywheel since then. (both sa50)
Posted: Thu Aug 09, 2012 12:06 am
by veedubh20
you need to ck ohm meter for continunty headlight. if no reading then headlight need to replaces.
