Bought 86 spree today can't get started
Posted: Tue Aug 07, 2012 8:32 pm
by jme
Has fresh gas, new spark plug, has spark and compression, I crank over and over and doesn't even sound like it wants to start. Any thoughts or suggestions
Re: Bought 86 spree today can't get started
Posted: Tue Aug 07, 2012 8:45 pm
by charleswymer
u say it has compression but how much compression does it have
Posted: Tue Aug 07, 2012 8:55 pm
by jme
Not sure just know air comes out the exhaust when I try to start it. I have a friend who can check it for me. Do u know what it should have?
Posted: Tue Aug 07, 2012 9:08 pm
Unless you check the compression with a gauge, you have no clue what the compression is. Moving air will happen at 40 PSI but the engine will never even fire there. The magic minimum number is 114 PSI but and engine will run with 90 PSI.
Posted: Fri Aug 10, 2012 5:05 pm
by JONESER
Make sure you totally clean the carb too. You didnt say whether you did that or not...
Posted: Fri Aug 10, 2012 5:30 pm
by jme
Checked the compression and put on new head gasket. Only 70psi. Kinda sounds like it wants to start. Would be willing to sell if anyone's interested. I'm in Saginaw and can Txt pics
Posted: Fri Aug 10, 2012 5:35 pm
by noiseguy
I bet it doesn't have an air filter. Won't start without one.
Posted: Fri Aug 10, 2012 5:43 pm
jme wrote:Checked the compression and put on new head gasket. Only 70psi. Kinda sounds like it wants to start. Would be willing to sell if anyone's interested. I'm in Saginaw and can Txt pics
Some Sprees run at 70 PSI and most will not.
Did you do the compression test with the throttle at WOT?
Posted: Fri Aug 10, 2012 5:53 pm
by jme
I just turned it over 5-6 times didn't mess with the throttle when checking the compression
Posted: Fri Aug 10, 2012 6:18 pm
by jme
It's missing the hose from the carb to the air filter. You think that would stop it from starting?
Posted: Fri Aug 10, 2012 6:19 pm
by jme
noiseguy wrote:I bet it doesn't have an air filter. Won't start without one.
Posted: Fri Aug 10, 2012 9:14 pm
by noiseguy
jme wrote:noiseguy wrote:I bet it doesn't have an air filter. Won't start without one.
Heh. You mean it's missing the air intake duct from the carb to the airbox
It will not start like that. You'll need to obtain a new one.
Search "barn find" in Wikispreedia for more on these bikes.
Posted: Fri Aug 10, 2012 9:24 pm
by jme
Thanks
