I was stuck on a long and dry teleconference and created an interactive excel spreadsheet to calculate how much oil is needed to add to gas to get to my desired 32:1 premix ratio. Because I am terrible at quick mental math at the gas pump (huffing to many fumes perhaps) I wanted a quick check to know how much to add based on X.XX gas. Unfortunately I can't add .xls or .xlsx files to the forum so you could play with the numbers yourself. Instead below is a text version. I printed off mine and will be keeping it with my oil measuring cup under the seat to use at the pump.
32:1 Mix Ratio
Fuel Gal _ Oil oz _ Oil cc
1.00_ 4_ 118.3
1.50_ 6_ 177.4
0.05_ 0.2_ 5.9
0.10_ 0.4_ 11.8
0.20_ 0.8_ 23.7
0.25_ 1_ 29.6
0.30_ 1.2_ 35.5
0.40_ 1.6_ 47.3
0.50_ 2_ 59.1
0.60_ 2.4_ 71.0
0.70_ 2.8_ 82.8
0.75_ 3_ 88.7
0.80_ 3.2_ 94.6
0.90_ 3.6_ 106.5
32:1 Oil premix ratios
Re: 32:1 Oil premix ratios
gas meter pump .250 1 oz oil
.500. 2oz oil
.750 3 oz oil
1 gallon 4 oz oil.
add oil in the gas tank. first vary on oz(s) . need to match gas meter pump.
this is the easy way to do it.!!!
go get a squirt bottle from the garden department on the weedwacker area.
oil in the tank will be mix by pour the gas in the fuel tank.
.500. 2oz oil
.750 3 oz oil
1 gallon 4 oz oil.
- Trafficjamz
free premix app for android and iphone
- patthesoundguy
I use the android version called fuel/oil mix calculator it rocks. I used to use a calculator, then an excel calculator that I made in my pocket pc.Trafficjamz wrote:free premix app for android and iphone
It is also easier to calculate here in Canada because everything is metric.
Greeting:
Are we overthinking? Four times the gallon count equals the number of oh-zees of oil.
