Spree Highway Speed Pipe build
Posted: Mon Aug 13, 2012 7:38 pm
by noiseguy
All:
Will use following to document how the Spree pipes get built.
First, need a chamber. This is what we'll be using:
- pocket_bike_exhaust.gif (15.19 KiB) Viewed 7764 times
And you need a downpipe:
or
Re: Spree Highway Speed Pipe build
Posted: Mon Aug 13, 2012 11:49 pm
by Videonut
sounds interesting... and fun
Posted: Wed Aug 15, 2012 9:28 am
by two4one
Looking forward to getting mine. BTW has anyone ever recorded one of your pipes with the motor running? I'm curious how they sound.
Posted: Wed Aug 15, 2012 10:23 am
by noiseguy
They sound like a dirt bike to me.
Posted: Thu Aug 16, 2012 8:27 pm
by elitedio
I did about the same thing on a Yamaha Zuma 50
I ran it for while but thought that on the zuma with a stock cylinder it needed a lower rpm band and cut the center section out and welded in a piece of tubing. Ending up with this.
Back to your build Noiseguy!
Posted: Thu Aug 16, 2012 10:19 pm
by kingkamehameha
elitedio wrote:I did about the same thing on a Yamaha Zuma 50
If anyone knows how to build 2t pipes its you!
Posted: Fri Aug 17, 2012 4:00 am
by paulpauly7
its really not that hard to do if you have time a welder and some pipes to work with a bit of trial and error you get the hang of it as you go and learn what works and what doesnt
