ax24 belt and gear gasket
killingspree1985
Post by killingspree1985 »
i installed an ax24 belt and it made my top end slower than the stock bando. why is this an upgrade? and i installed tazland gears and made a new gasket but its leaking.......where can i find a stock replacement??
abreen89
Post by abreen89 »
Did u do a bbk and carb aswell?
'89 Honda Elite SB50p STOCK
'86 Honda Aero NB50 Stock
killingspree1985
Re: ax24 belt and gear gasket
no i wanted to buy one at a time and see the results with each.Does it only work with a bbk or what? left carb alone as well
patthesoundguy
Post by patthesoundguy »
with the belt and gears and no BBK you will have terrible take-off. Its possible you just don't have the grunt to get it up to speed. Or somthing else is wrong
